586,390 active members*
2,817 visitors online*
IndustryArena Forum > CAM Software > Mastercam > mold scribe lines with 9.1
    Dec 2004
    55
    Dec 2008
    3111
    You have to realise what part of the tool is following the toolpath, you have the tooltip selected, which is ideal for planar ( 2D ) paths, but goes a little askew when it comes to 3D. You would have to modify the wireframe geometry to get anywhere near the correct paths needed.
    There are a couple of methods
    - create geometry that the ballnose centre is to travel along ( can be awkward to create this geometry for the less advanced users, but it is a method )
    - use the "Surface Finish Project" strategy, you select the pathline of what you want the toolaxis to follow, and the "drive surfaces" & how much you want the tool to stay off the drive surfaces ( for you it would be -0.003" ).
    This calculates a path relative to the defined tool ( it doesn't even need to be a ballnose ) on the surfaces keeping the toolaxis on your selected "curves"
    Dec 2004
    55
    woops, I maeant
  1. Sheetcam + Scribe + Mach3 - Z Axis Movement
    By unixadm in forum Mach Software (ArtSoft software)
    Last Post: 07-01-2011, 11:16 PM
  2. Custom Screen for Plasma/Scribe MP3000 DTHC!
    By Voodoo Vintage in forum Screen Layouts, Post Processors & Misc
    Last Post: 01-06-2011, 05:27 PM
  3. Replies: 1
    Last Post: 08-11-2010, 01:59 PM
  4. Machining 'scribe' and 'ruler' lines
    By PCS74 in forum MetalWork Discussion
    Last Post: 01-12-2008, 02:04 PM
  5. Lines in mold
    By DH2000 in forum Moldmaking
    Last Post: 01-07-2008, 03:50 AM
