does anyone know anything about plasmacam? there program has way to much info to enter and there manual has you jumping from on page back to the next. I have a powermax 600 with a pac123 torch and they give you 3 settings to enter in a program that gives you 50 settings.
so I thought I would ask the real pros. the guys that use the cutters.
I have FINECUT, UNSHIELDED & SHIELDED Consumables I'm trying to cut 10,12, & 14 ga. i got everthing fix on the table( water in lines, bad ground, dhc fixed) messed with the settings in between screw ups and now there all screwed up. just need help with the settings
this was ment to be part time but turning into full time
any help would be greatful.
[email protected]
Clint.
