586,889 active members*
4,773 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > pm30 lv on/off switch questions
    Jul 2006
    35
    Is this normal? The machine will only come on if I have the forward/reverse switch in either the forward or reverse mode, not in the "0" mode. If I move the switch to the "0" mode the machine shuts off.
    Also, in either mode the spindle spins at about 40 rpm at it's lowest setting. There is no way to NOT have the spindle spinning when the machine is on.
    thanks,
    H.
    Dec 2009
    1416
    Yes, the switch needs to be in FWD or REV to start the drive and to run the machine. Sounds like the low end calibration is set a little high so the drive is providing some power to the motor even if the pot is bottomed out. The drive likely has adjustments to set that. I don't usually count on the thing not spinning with the drive energized. If the spindle is not supposed to be moving right now then I want it 'off' not just turned down. It doesn't have the pot+switch like the X2 does where it's physically 'off' at the bottom of the speed adjustment.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
  1. Taig/Xylotex/Switch Questions
    By dunner in forum Benchtop Machines
    Last Post: 02-01-2011, 10:03 PM
  2. Replacement for master switch/reversing switch on HF 8x12?
    By novahobbies in forum Benchtop Machines
    Last Post: 06-29-2010, 02:05 PM
  3. More limit switch questions
    By ljoe1969 in forum Xylotex
    Last Post: 05-16-2005, 06:02 PM
  4. Limit Switch / Home Switch in Software
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-02-2004, 12:58 AM
