587,136 active members*
3,729 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF2 Run program with door open !!
    May 2011
    How can I run a program with the door open, the setting 51 doesn't override the door open alarm on my machine (it's a 2010 model). I need help....Thanks,Don
    Jul 2005
    12177
    You don't, unless you fudge the lock mechanism or trace wiring and bypass sensors. Which is not a wise thing to do during the warranty period.
    http://www.cnczone.com/forums/haas_m...oor_locks.html
    http://www.cnczone.com/forums/haas_l...cks_crazy.html
    I had the same problem setting #51. Changed it to "Y" & nothing changed. Hit "write" and respond to warning "are you sure" sort of thing, hit Y.
    You have to do this every time you power up.
    Apr 2011
    Newer Haas mills need parameter 57 door stop spindle changed from 1 to 0 as well as changing setting #51.
    DJ@S&W
  1. Door open request
    By zippyd in forum Daewoo/Doosan
    Last Post: 05-09-2016, 11:25 AM
  2. Open tool changer door
    By Jedi in forum Haas Mills
    Last Post: 04-19-2011, 11:14 PM
  3. Door Open
    By North Forty in forum Haas Lathes
    Last Post: 09-02-2010, 04:46 PM
  4. TL-1 door open alarm won't go off!
    By donsbad89 in forum Haas Mills
    Last Post: 09-25-2009, 04:01 AM
  5. kira vtc30a door won't open
    By nevron in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2008, 03:30 PM
