Originally Posted by
Superman
Are you new to Mastercam ?
( This is not a dig at you, it sets us up on how we explain things, and possibly adding on where to find them )
Has the machine definition and machine control been configured correctly ?
as well as the post ?
It is not as simple as just loading a post to a default machine and control file, and expecting the code to be correct.
All code is, usually, manually checked & edited to run thru the machine, then the post, with the associated files, are "adjusted" to give the same code as what was proved previously.
