If you only use the convertor for the mill, probabally the best way would be to get rid of it and run a VFD with 1ph in - 3ph out, once you calibrate it the speed will be fairly constant and a known as it will be tied to the frequency selected, and can be displayed on the VFD. I got rid of the Vari-speed pulley on my Excello's and used direct timing belt drive with VFD control up to twice the rated rpm of the motor (120Hz).
Al.
