586,770 active members*
8,766 visitors online*
    Apr 2008
    38
    Heidenhain "Angle Reference Missing" error
    Hi all, I've just loaded a program into an old Bridgeport Interact 412 running Heidenhain TNC 151, that I created using Mastercam.
    I've come across an error while trying to do a 26x6mm slot, using a 6mm cutter (set to 5.98mm diameter). When it gets to line 54 I'm met with the error "Angle Reference Missing".
    40 TOOL CALL 3 Z S3500
    41 M6
    42 L X+80.950 Y-0.010 R0 F9999 M03
    43 L Z+10.000 R0 F9999 M8
    44 L Z+2.000 R0 F9999
    45 L Z+0.000 R0 F100
    46 L X+90.000 Z-0.474 R0 F200
    47 L X+90.007 Y-0.007 R0 F200
    48 L X+90.010 Y+0.000 Z-0.475 R0 F200
    49 L X+90.007 Y+0.007 R0 F200
    50 L X+90.000 Y+0.010 Z-0.476 R0 F200
    51 L X+80.000 Z-1.000 R0 F200
    52 L X+70.000 R0 F200
    53 CC IX+0.000 IY-0.010
    54 C X+69.990 Y+0.000 DR+ R0 F200
    55 CC IX+0.010 IY+0.000
    56 C X+70.000 Y-0.010 DR+ R0 F200
    57 L X+90.000 R0 F200
    58 CC IX+0.000 IY+0.010
    59 C X+90.010 Y+0.000 DR+ R0 F200
    60 CC IX-0.010 IY+0.000
    61 C X+90.000 Y+0.010 DR+ R0 F200
    62 L X+80.000 R0 F200
    63 L Z+10.000 R0 F9999
    64 M9
    65 M05
    I'm not too familiar with Heidenhain programming to be able to see what's wrong, any programs are made using Mastercam and I'm used to Fanuc .
    Can anyone shed any light on this for me please? Is it because the cutter rad is so close to the slot rad?
    Dec 2015
    11
    Re: Heidenhain "Angle Reference Missing" error
    Quote Originally Posted by Lugy View Post
    41 M6
    64 M9
    65 M05
    Hi Lugy,
    Did you manage to find a solution to this problem?
    I am having a similar problem; it stops at line 140 (code is below) with same error/warning message: "Angle Reference Missing". Any help would be appreciated
    Shumail
    134 L X+57.159 Y+52.428
    135 L X+52.258 Y+51.337
    136 L X+45.076 Y+49.609
    137 L X+42.456 Y+48.944
    138 L X+40.005 Y+48.383
    139 CC X+21.810 Y+119.199
    140 C X+30.496 Y+46.601 DR-
    141 CC X+30.497 Y+46.586
    142 C X+30.496 Y+46.571 DR+
    143 L X+34.491 Y+45.911
    144 L X+38.167 Y+45.106
    145 L X+49.195 Y+42.341
    146 L X+52.258 Y+41.604
    147 CC X+84.256 Y+173.158
    148 C X+62.673 Y+39.499 DR+
    149 CC X+83.734 Y+184.622
    150 C X+73.088 Y+38.366 DR+
    151 CC X+87.799 Y+223.863
    152 C X+76.082 Y+38.153 DR+
    153 CC X+76.157 Y+39.338
    154 C X+77.151 Y+39.988 DR+
    155 L X+75.446 Y+42.595
    156 CC X+76.440 Y+43.245
    157 C X+76.523 Y+44.429 DR-
  1. Replies: 4
    Last Post: 07-10-2015, 04:01 PM
  2. Need advice Setting Up production: 4 to 8 sq ft of 39" long 1x1" AL Angle daily use
    By aluminumwelder in forum Material Machining Solutions
    Last Post: 09-27-2013, 08:21 AM
  3. X Axis "Goes Off Pattern", "Awry", "Skewed", "Travels"
    By DaDaDaddio in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-06-2013, 09:59 AM
  4. Romi 10 Lathe "No. 2003 Reference Required"
    By FourPoints in forum Uncategorised MetalWorking Machines
    Last Post: 09-04-2010, 10:03 AM
  5. Bridgeport 760\22 Heidenhain 370 "error 2 tool def"
    By JNFSWE in forum Bridgeport / Hardinge Mills
    Last Post: 08-26-2008, 07:45 PM
