hello everyone,
I ve an assignment in which i made use of ProE to design, powershape to modify and powermill to simulate.
the first one, drilling of six holes(diameter 7.5mm) equidistant from each other in a circular array on flat plastic plate. After the program was generated, it was drilled using an interact 3 axis milling machine.
Secondly, i engraved my intials usiing thesame softwares and machine, on a wooden cube.
Can any one tell me the general difficulty and precautions with this process. what are the likely constraints associated with these process.
What are the limitations of hot rolling and cold rolling .
thanks
