586,345 active members*
3,229 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 11M Check Instruction during boot
    May 2011
    Angry Fanuc 11M Check Instruction during boot
    Hello all,
    I have a Mori Seiki MV 80 with a Fanuc 11M control.I have replaced the master board but during boot all I get on crt is a check instruction meassage with a lot of hex addresses. I am assuming this to be a rom/ram board issue or even software related. Any help would be greatly appreciated.
    Apr 2009
    1379
    what does the motherboard led read?
    Did you check jumpers on the new board?
    Does it come on in IPL mode?
    May 2011
    Quote Originally Posted by memoryman View Post
    Motherboard status is "E" on 7 segment led.
    Jumpers on new board are the same as old board.
    I can get to IPL mode but not by the usual means of "-" + "." only by pressing the reset button?
    Apr 2009
    1379
    your problem could be the BMU, powersupply or almost anything. Why was the mother board replaced?
    May 2011
    This control has several boards connected, Add. axis, Cassette, Rom/Ram, bmu, I have removed the bmu board as well as the add. axis cards and still the same problem. The masterboard was replaced because it was showing an "8" on 7 segment led.
    Apr 2009
    1379
    sorry about all the questions.
    Here are some more.
    "I have removed the bmu board as well as the add. axis cards and still the same problem". Do you mean that these boards were swapped with known good ones?
    Was the new bmu properly initialised? Are the power supply voltages correct?
    What does the IPL screen show?
  1. how to graph check in fanuc 21i-tb
    By ming035 in forum Fanuc
    Last Post: 01-16-2010, 01:13 PM
  2. PROGRAM CHECK FANUC O-T
    By Daniel Boone in forum Fanuc
    Last Post: 11-09-2009, 05:28 AM
  3. fanuc 10m Io030 check sum error
    By skippyfix in forum Fanuc
    Last Post: 07-02-2009, 12:52 PM
  4. FANUC 0i-TC OS boot files required!!!!!!
    By biazbaba in forum Controller & Computer Solutions
    Last Post: 08-06-2008, 12:52 PM
  5. Fanuc OTa In Position Check Parameter
    By thardy in forum Fanuc
    Last Post: 07-11-2008, 08:29 AM
