586,745 active members*
6,564 visitors online*
    May 2011
    MV-65 Coordinate parameter
    We have a Mori Seiki MV-65 (SN 262) with a 10M control that just recently had the parameters restored. Everything performs fine with the exception of the reset button. If the reset button is pressed this machine seems to lose its position. The position the machine is reset is the new zero. Example:
    If the "distance to go" reads X 5.500 inches, and the control is reset, you can move the machine to any postion recall the G54 work offset and it will still say "Distance to Go" X 5.500 inches. The only way to resolve is to home the machine after each reset.
    Before the parameters were reloaded the reset would only reset the program not the coordinates.
    I'm sure it is a parameter setting. Any input will be appreciated. I have talked to Mori and Fanuc extensively on the issue.
    Oct 2015
    Re: MV-65 Coordinate parameter
    Hello ,
    I'm having the same problems with our MV-55 Mori Seiki with the same 10M control. Have you found any resolution to this issue? I've tried everything I can think of, and nothing seems to change the result.
    Thank ,
    Frank
  1. Work Coordinate G54, G55, G56
    By mousongie in forum Fagor Automation
    Last Post: 02-06-2013, 12:00 AM
  2. Coordinate
    By Troncatore in forum Mach Mill
    Last Post: 05-31-2011, 09:30 PM
  3. how do I use 3d coordinate conversion?
    By atrus9999 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-29-2010, 10:14 PM
  4. Replies: 0
    Last Post: 11-11-2008, 02:35 AM
  5. Work coordinate additional G codes parameter
    By djmcdaris in forum Fanuc
    Last Post: 02-27-2008, 10:41 PM
