586,535 active members*
2,831 visitors online*
    Dec 2010
    ATC not ready alarm
    Help please for a Newbie....
    I stopped the machine in mid-process and can't do anything now without the warning - ATC not ready. I'm sure it's an easy one to fix if you know what you are doing!
    The machine is a Denford Mill (15 years old). The controller is a Fanuc OM
    Cheers - John
    Sep 2008
    138
    May be the arm of atc tool change not in position.
    24223
    You need the OEM M code list to see if the T.C. moves can be input individually via MDI to get it back in sync.
    Al.
    Jul 2010
    HI !
    Try to bring back the ATC arm in position by turning manual the motor that drive the arm until the in position sensor lights.
    Dec 2009
    26
    You should have a manual switch to move the changer out and back. In MDI mode do a M19 command to orientate the spindle then switch to manual and use the manual switch to put the changer back in position.
    You cant do anything to the ATC until you do a M19.
  1. Improper V-Ready Off Alarm???
    By Crashmaster in forum Fanuc
    Last Post: 09-09-2019, 04:55 AM
  2. Replies: 8
    Last Post: 09-03-2015, 04:46 PM
  3. fanuc 0m servo not ready 401 alarm
    By keithc in forum Fanuc
    Last Post: 04-16-2009, 02:45 PM
  4. O-T not ready alarm
    By Ryno in forum Fanuc
    Last Post: 09-19-2008, 03:14 PM
  5. Taig CNC ready, how ready is that?
    By JB_in_Fla in forum Taig Mills / Lathes
    Last Post: 03-31-2008, 10:47 PM
