587,065 active members*
3,898 visitors online*
Results 1 to 8 of 8
    Jul 2005
    179
    RS-232 program read
    What is the sequence for uploading programs using RS-232 for a Fanuc OT? I can down load but can't upload.
    H
    Feb 2004
    52
    Transfer program from PC to OT control
    On control edit - program - input
    you will see LSK on control
    send prog from PC
    Transfer program from OT control to PC
    get PC ready
    On control edit - program - progam number (example O0001) - output start
    hope this helps
    regards
    Les Robbins
    EditComm - CNC communication software - Les Robbins CNC Services
    Jul 2005
    179
    Hi Les,
    I can send from OT to PC, no problem, just like you described. I've tried receiving programs from PC and I do get the LSK on the control but I get the 086 error. I don't know if I have tried it when in Edit - Program tho. That would put the current program on the screen correct? And the Input would over write the current program? I have tried it in Edit - Program - Program. Let me give it a try,
    H
    Feb 2004
    52
    086 error means the DR signal is turned off.
    Check your external RS232 cable pinout (look on my website in FAQ - url below)
    There should not be any connection to pins 6, 8 and 20 other than links at the control end (25 pin D type).
    I seem to recall a problem like this year ago because the PC was pulling down the DR signal when sending to the machine
    The other possiblity would be a faulty serial port on the control
    Hope this helps
    regards
    Les Robbins
    Jul 2005
    179
    I'm using the same cable from the PC to an A/B box that goes to my Heidenhain TNC145 and the Fanuc OT. Let me check that out. I down loads just fine, but I'll check it out.
    Thanks Les!
    H
    Jul 2005
    179
    Thanks Les, I checked your cable on the FAQ and my cable does not have pin 8 jumped with pins 6 and 20. I also have my pins 2 & 3 crossed. I tried uploading again using Edit - Program - Program - Input and I do not get the 086 alarm, the LSK blinks and the PC says Sending, but no bytes ever transfer, it just sits there. I'm going to make up a cable and see what happens. I don't know why I can down load tho?
    H
    Got it, made up a new cable and works fine. Thanks for all the help!
    Apr 2010
    45
    you might want to check your parameter setings on your 0 T control
    Jul 2005
    179
    Thanks guys. I did not have the 8 pin jumped with the 6 and 20. I jumped the 8 and it works fine. I've got it on an AB box and the "new" cable also works with my TNC145
    H
  1. Replies: 0
    Last Post: 12-27-2010, 09:55 AM
  2. My CNC doesn't read G02 X Y I J
    By Bazz in forum G-Code Programing
    Last Post: 10-07-2008, 03:40 AM
  3. 10T-F READ READ READ READ READ READ
    By dcoupar in forum Fanuc
    Last Post: 03-27-2008, 11:39 PM
  4. Replies: 32
    Last Post: 05-10-2006, 02:08 PM
  5. Must Read for All
    By CBNDude in forum News Announcements
    Last Post: 07-22-2005, 03:14 AM
