586,675 active members*
2,605 visitors online*
Page 1 of 7 123
Results 1 to 20 of 127
    May 2010
    118
    Build Thread 1
    Well,
    First thread in the new forum. What fun!
    My build is coming along. The case is done and being painted. The first three metal parts have been blued, laid out, and cut. Drilling and tapping is in progress (slow progress).
    I'm trying to do get the best precision I can, so the drilling process is:
    • Put the part in the vise.
    • Locate the center-punch mark with a center finder.
    • Lock down the vise.
    • Remove the center finder and start the hole with a spotting drill.
    • Remove the spotting drill and complete the hole with the correct size drill bit.
    • If the hole is threaded, remove the drill bit and install a dead center to keep the tap aligned.
    • Tap the hole.
    • Move the part to the next hole and start over!
    Part number 3 took about an hour from start to finish. Doing all operations on one hole before moving the part adds time, but ensures everything stays concentric.
    One note. A decent drill press vise really helps, especially when you need to drill several holes with a common center-line as on parts 1, 3, etc. Locate one of the holes with a center finder and then bolt the vise down securely. Now you can move the part side to side to drill the other holes knowing that they will all line up.
    I'll post some pic's as soon as I can.
    Randy
    Sep 2010
    Randy,
    Great first build post to our new Momus forum.
    I hear you when you talk about the amount of driling and tapping. I went out and bought myself a very basic bench top drill press and can't imagine doing all drilling without it. I would spend a couple of hours at night working on a piece or two. Any more than that then I would start rushing things and that was not good. Eventually I go them all done and it was really cool to see how the pieces scattered about my work bench came together.
    It was all worth it when I finished all the components and put them together to look like attached photo.
    Next step for me is the wood base and then the electronics.
    Dave
    May 2010
    118
    Dave,
    Wanna swap - your carriage for my case?
    I agree, a drill press is pretty much required if you want to get decent precision. I've got a decent one having put together a fairly nice wood shop over the years. I can only work an hour or two at a time as well. I want to get at least as good as the +/- 0.005" Bob says the machine is capable of, but my precision suffers if I push too hard.
    I ordered my electronics package today. I got the NEMA 23 kit from CNCRouterParts. It should be here next week. I still need the drive bits and switches, and then I will have everything. It should come out right at $800 by the time I'm done (minus software). Not a bad price for what should be a pretty good machine.
    I hope to make a fair bit of progress over the weekend, but I expect it will be at least a full week before all the metal parts are done. It should go together quickly after that though.
    Pictures tomorrow. Gotta play golf this evening...
    Randy
    Randy
    Apr 2009
    5516
    Glad to see you guys got the sub-forum going... although I might not go this route just yet, I do plan to build one to use in my office as a prototype machine, and the enclosure design fits right in.
    I have been cutting aluminium on my CNC router for a while now, and was gound to cut the parts for this machine with it. I have all the metal for this as well as the steppers, plywood, bearings, etc. but am planning to build a mini-mill first, then use it to cut parts for this machine...
    Dec 2006
    202
    Randy, your drilling procedure is impressive. I don't know if I would have the patience for that! But the results should be well worth it. Any photos of the base?
    I ended up marking out all the holes on all of the pieces first. Then I drilled all of each size hole. For me at least, I found it was quicker to unclamp one part, and drop the next one in place, rather that constantly switching drill bit sizes.
    Dave, that gantry assembly is looking good.
    I also did all of this with a cheap bench top drill press. It was like $99 at Home Depot. If I had it to do over again I would probably take some time to find a higher quality used one. When drilling a hole with this one I can watch both the column and the table flex considerably. To the point that even with moderate drilling pressure the drill bit is suddenly no longer perpendicular to the table! One addition that was worth the money was a cheap cross slide vice I picked up at Harbor Freight. It is typical HF quality, but it is very handy.
    Keep the photos coming.
    -Bob
    May 2010
    118
    Progress Update
    All,
    It's not Friday, late again, sorry. Here are a few shots anyway.
    The base is done.
    Well, it is done but for the rear flange, rear door, and cover. Done enough to want to start working on the metal bits anyway. Mine is almost exactly per plan. It is 1/4" short from front to back due to significant variance in the size of big-box "Handy Panels". Only one of the 24" x 48" panels I bought was actually 24" wide. By the time I trued them up the best I could do was 23.75" so that became the depth of the base.
    I goofed reading the plans and the relief cuts on the left side are not in the right place. They are spaced the right distance apart, just not located correctly fore and aft. I could not find 3/8" ply locally either. Actually it's all metric anyway. I used 1/2" which is closer to 7/16". It worked out just fine. I did use the panel-raising bit in the router to make the bearing tracks. It worked great.
    As for the drilling process, I have decided I don't need to do it with most holes as it is very time consuming and Bob has made most things adjustable so dead-on precision is not needed. I am doing it where two or more parts join and there isn't a lot of room for adjustment. Stepper motor mounts for example.
    Here are a few pic's of the process.
    I do tap all of the holes this way. It keeps the tap straight. Also, by providing support to both ends of the tap and wrench it greatly reduces the possibility of breaking a tap. Getting taps out of aluminum is miserable process. It's usually easier to just scrap the part and start over.
    I learned this process from a series of videos produced by MIT. They have a Machine Shop course for people who must produce prototypes for their coursework. If, like me, you are not a machinist these videos are great. There were two on drilling and tapping holes alone. You can find them by doing a Google search for "MIT Machine Shop Video. There are 10 in total. Here's a link to the first one: MIT TechTV – Machine Shop 1
    Randy
    P.S. A question. How does one post those expanding thumbnail photo's that most people seem to use?
    May 2010
    118
    Bob,
    Your method for making the parts is certainly the most efficient way. Unfortunately, my psyche won't allow it.
    I can't stand to do the same thing over and over, and I have to see progress. Making one or two parts at a time from start to finish fills both needs and keeps me sane.
    It's even worse that that though. If I were to show you a picture of my shop you would see three projects in progress. A tall-clock for my wife, a 1/4 scale Rearwin Speedster airplane, and your router. The lattice-work looking thing behind the tap picture in my previous post is one of the wing panels for the Rearwin.
    Randy
    Mar 2004
    1806
    "P.S. A question. How does one post those expanding thumbnail photo's that most people seem to use?"
    Save your photos to a convenient spot on your drive and then in the advanced mode, use the attachments tool (paper clip) to upload the pictures. It will then put them as thumbnails in your message.
    Art
    Apr 2009
    5516
    Randy that looks great so far! I wish I had your patience as far as tapping. Some people cringe when they see me tap; I just chuck it on the cordless drill and go at it! I have one drill with a tapered tap, and another with a bottoming tap, and they come out pretty straight...
    Actually I did use to use the drill press; but I would put it at the lowest speed, then I would put my piece in the clamp but loose, and start feeding the tap. I have to keep another hand on the off switch, because once I sense it's about to lift I shut the drill press off right away and manually reverse the tap. But the cordless drill works faster...
    The guys on American Chopper chase tapped holes all the time with the cordless drill, so I guess it's almost OK...
    May 2010
    118
    Art,
    Thanks! I never thought of using the attachment feature. Makes sense though. I'll do that in the future.
    Louie, I've done that a time or two myself. But I've broken a few taps that way too...
    Randy
    Apr 2011
    router clamps
    Ok gang, My ACETAL (delrin) showed up in mail on thursday along with a chunk of ABS plastic. I wanted to try out delrin clamps to see if they would be rigid enough and yield similar results as the aluminum version. I also wanted to test out my custom designed clamps for the Rigid 2401 router so delrin was a good way to prototype quickly and costwise wasn't too bad. Aluminum was supposed to show up friday but it didnt make it. So will only post pics of the delrin version.
    Here's a shot of the clamps after initial cut and then after I seperated the halves and drilled/tapped/slightly de-burred everything...
    Apr 2011
    next up you can see the router with the clamps attached and a close up of the new mounting location on the z-rail. The new mounting location is a must because of the contour area on this router is in the way if you use the plan mount locations. Also Lowering this mount makes it a lot easier to square the bit.
    Apr 2011
    finally, testing the rigidity of the delrin clamps by machining another set of clamps from ABS. I am scrapping the ABS clamps as the finish isn't all that great. the high RPM is melting the plasic a bit. I have not tried any aluminum cutting with these clamps but they are very sturdy and in wood and plastics they are performing as well as the aluminum clamps did.
    Apr 2009
    5516
    Quote Originally Posted by bjesson View Post
    Hey bjesson, those came out great! I just thought of this; on my CNC table, I used black paper-based phenolic for the entire frame, including the notor mount, and it has proved to be very solid. I can check to see if I have some chunks wide enough to try on. Thye're 1" thick also, so there should be evevn more clamping force and support...
    May 2010
    118
    bjesson,
    Way cool!
    Wanna sell me the delrin set once you get your new aluminum ones done? I could use 'em to make an aluminum set for myself, and then pass them on to someone else.
    Randy
    Feb 2009
    499
    Those acetal clamps should work just fine. I've had the one on my table for a Bosch Colt for some time now, and I cut aluminum with it without tooling marks just fine.
    This particular one in the photo is off a Probotix, who sells them for a variety of different sized routers.
    Nice build, btw bjesson.
    It's got me wondering about running two tables - how much trouble would it be to switch stepper and signal cables into the G540 from my current table into one of these tables. The SuperPID kind of complicates it. I guess there is an easy way to load different versions of Mach for each machine? May be more trouble than its worth.
    "72.6 per cent of all statistics are made up on the spot." - Steven Wright
    May 2010
    118
    Electronics Arrived
    My Electronics package arrived from CNCRouterParts yesterday. Everything looks good. I know Gecko has their manual available online, and it is pretty good. Unfortunately, there is no information at all for the power supply.
    Anyone have any experience with this PS? I can figure out where the line cord goes, and I can put a meter on the other posts and figure them out, but I would sure like to know what I am doing!
    Also, any recommendations on hook-up wire? I'm guessing 14 to 16 gauge stranded with solder terminals on the supply end and stripped/tinned on the Gecko side should be sufficient.
    The motor cables are nice, but now I need to figure out a neat way to get them through the side and then plug the gap so the electronics compartment stays somewhat dust-free. I figure I will make a template and route a rectangular hole big enough for the molded plug to fit through. Then I need to make some kind of a cover.
    Randy
    Sep 2010
    Cabling
    Randy,
    I bought a replacement tool cable from HD for the connection of PSU to wall outlet - green to ground, white to N, black to L. As for PSU to Gecko I just have a temporary set up with 2 strand + shield 18 ga wire right now.
    Don't forget your Estop button. Post #19 in this thread http://www.cnczone.com/forums/diy-cn...ko_g540-2.html provides good info and photos of connections.
    Dave
    Apr 2011
    Quote Originally Posted by groswald View Post
    bjesson,
    Way cool!
    Randy
    My aluminum arrived yesterday and I am halfway done machining a new set of delrin clamps for the bosch router. If the aluminum set come out good I will make my delrin clamps available. I may cut another set of delrin clamps just to have a spare. As stated earlier, if anyone needs clamps I will cut them for a small fee. Delrin isnt free or cheap
    Thanks!
    billj
    Apr 2011
    Randy
    I have the same power supply. all I did was supply it with AC on the 3 terminal side and adjust it for 24 volts on the dc side. Depending driver board you are using it should have a range of like 12 - 36 volts. You shouldnt need full DC power for the NEMA 23 motors but 24+ volts should do it. Then it is just a pair of wires from DC to driver. 18 guage copper should do it.
    Bill j
Page 1 of 7 123
  1. My JOES build thread......
    By craigjh in forum Australia, New Zealand Club House
    Last Post: 04-06-2012, 09:54 PM
  2. TXFred's X2 build thread
    By TXFred in forum Benchtop Machines
    Last Post: 04-21-2011, 01:10 PM
  3. Build thread X3 and G0602
    By SmoggyTurnip in forum X3/SX3/G0619/G0463
    Last Post: 04-01-2011, 09:58 PM
  4. MTW PM20LV Build Thread
    By Enraged in forum Benchtop Machines
    Last Post: 11-30-2010, 06:31 PM
  5. CNC guitar build thread.
    By Drools in forum Musical Instrument Design and Construction
    Last Post: 11-23-2010, 05:53 AM
