586,499 active members*
2,687 visitors online*
    Aug 2005
    50
    EaziCNC and Mach 3.....Now New Controller!
    I've had for sometime a CNC2x box and EaziCNC Version 2 software from Conqueror Design & Engineering Ltd. Over the last few weeks I've been having a really good push to make some "proper" parts off my converted CNC machine.
    Over the last week or so I've been having a problem that when I'm machining the machine seems to just want to go off in a direction / position nothing to do with whats in the NC code. I did originally think it was down to the post processor from my CAM software but when I re-run the code its fine?? Weird hey!
    This comes to my second part I'm convinced its something to do with the CNC2x software and the EaziCNC software. Has anyone come across this type of problem before?
    Now I'm thinking I want to go to Mach3 software....everyone seems to be using it and I'm sure it has a little more about it. But I now need to make myself a new controller. I'm thinking of using Zapp Automation products the CIB Industrial control interface Zapp Automation
    Has anyone used this and found it to be anygood?
    Ant
    Sep 2007
    359
    Quote Originally Posted by antsals View Post
    Ant
    After trying the CNC2 i decided that it was very poor, use Mach3 now and very happy.
    So any problem i would put down to the controller
    Phil
    Aug 2005
    50
    Thanks for the reply,
    I've had some information back from EaziCNC but I'm not convinced. I'm really convinced that going to Mach3 is the way forward.
    Ant
  1. Eazicnc or Mach3 for my mill?
    By JQ_Quint in forum Benchtop Machines
    Last Post: 07-19-2013, 10:13 AM
  2. mach 3/controller directions reversed
    By cncbcncb in forum DNC Problems and Solutions
    Last Post: 03-03-2009, 07:14 PM
  3. Replies: 2
    Last Post: 02-21-2009, 03:22 AM
  4. FeatureCam and EaziCNC
    By antsals in forum Uncategorised CAM Discussion
    Last Post: 06-06-2008, 06:38 PM
  5. Help Older CNC JR controller pinout for Mach III
    By sandtoysrus in forum Servo Motors / Drives
    Last Post: 03-17-2005, 08:14 PM
