I've some hot rolled flat bar stock stick welded (6011 rod, 1/2 x 4 & 1/2 x 2) into an unequal angle shape maybe 2 feet long and need to drill the welded areas. I figure it is probably hardened some and should be normalized or annealed first so I don't break the bit. I was thinking I'd try putting it in the gas grill for a while, then spot heat the welded area with a map torch and then leave it in the grill for a while longer.
Is this a viable plan? If so how hot and how long should I go with the grill ... with the torch ...?
Any other suggestions?
I'm a novice at this sort of thing so any help would be greatly appreciated
Mike
