You can also save and load settings from the floppy. unfortunatly probably not until you clear the problem sinces its keeping you from doing anything else.
To save or load from the floppy you simply go to the program loading section like your going to load a program and then hit the parameters/settings ect butoon and then type a name for the file and hit read/write depending on what your doing.
I would check the save option before commiting these actions just to make sure I remembered the right sequencing .
BUT like I said until the alarm is cleared you cant even try it. Also if you have your original manual you will have all of your settings in written form in there. It would suck to type everything in, but it is a last ditch option.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
