586,635 active members*
3,254 visitors online*
    May 2005
    89
    G-Code Line Numbers?
    Is there a program which will add line numbers to G-Code after it has been generated by Ace Converter? It would help me to have line numbers when debugging some of the strange things that Ace does.
    Skype me on imagineeringnz
    Intuitor: (noun)
    A person with a passion for learning and innovating that is so strong it is often more powerful than the desire to eat, sleep or seek personal wealth.
    Ummm . . . Guilty as charged.
    Check the box that says "generate block numbers" and ACE will add line numbers.
    May 2005
    89
    Thanks Gerry,
    Is there any way that Ace will save the last set of parameters ? ie. cut depth, rapid height etc.
    Intuitor: (noun)
    Not that I know of.
