Originally Posted by
RomanLini
You made me chuckle.
But seriously a couple of small fans will work well for extracting the heat not only from the water, but extracting that heat AWAY from the assembly as a whole. So that reduces the thermal expansion.
As for the amount of heat energy, if you know the spindle type and operating watts, and can guesstimate its operating efficiency you can get a ball park figure for how much heat will be extracted in the water.
As an optimal system you could just run the water through a finned air cooled heat tube (like a small radiator or oil cooler) with a decent extractor fan on it. And you can do that away from the machine so all the heat is extracted well away.
But there is a cool factor using the machine to cool itself.
Using the extrusion for cooling is an attractive idea, if the expansion isn't a problem. I have no idea how warm the water gets after 3 or 4 hours of running. It deserves to be tested to see if it is a viable solution.
I was getting carried away with it though, and the General Overkill solution came from a Peltier cooler for a laser diode I worked with in the early 90's. It was a little over an inch square, had 25 or more Peltier devices sandwiched between two thin ceramic plates, and worked the way I described it. It could heat or cool like a small heat pump. Very inefficient because of the power required to operate it but it was able to control the temperature to close tolerance in a very small space. I was picking at you again, and figured that you know what they are.
CarveOne
CarveOne
