586,635 active members*
3,092 visitors online*
Results 1 to 9 of 9
    Apr 2009
    134
    Calibrating axis
    I am having some strange problems with my second build,I cant calibrate all 3 axis correctly.
    I can make it to go exatly 30mm,making circles perfect,repeatability tests all ok but when I make for example 150mm circles it goes 151mm.
    OK,then recalibrated all axis,but then goes perfectly to 150mm but when tested the 30mm test it makes 29mm...
    I have no backlash that I can mesure.
    I am using 12mm x 1,75mm pitch
    threaded rods,directly coupled to my 2Nm stepper motors.
    Using this drivers:
    2/4 phase stepping stepper motor driver 70V/6A - eBay (item 300528146572 end time Apr-20-11 07:56:00 PDT)
    and 50V power supply.
    http://zeed-diyproject.blogspot.com/
    Dec 2008
    292
    Zeed, what control software are you using? Mach3, EMC2, etc?
    Don
    Apr 2009
    134
    Mach3...
    Dec 2008
    292
    Are you using the Mach3 calibration function?
    It is interesting that you get a calibration error going both ways. Usually, if you calibrate over a short distance then check longer distances, any errors in the short distance calibration will compound resulting in something like your 151mm instead of 150mm expected. However, when you calibrate over longer distances, then measure shorter distances, any errors in the longer calibration are minimized at shorter distances.
    Don
    Apr 2009
    134
    Well,things just got worst...
    When calibrated on 30mm distance,it gives me 146mm at 150 distance.
    when calibrated on 150mm distance it gives 31mm on 30mm distance.
    I used mach3 calibration function.
    Hard to explain with my bad english....so made some video and uploading to youtube now.
    edit:video
    Apr 2009
    134
    Well,tried today again ti fix this problem,but no luck...
    If it works fine on long distances then small distances are problem and vice versa..
    Is it possible that threaded rods are not linear with pitch?
  1. Calibrating a machine
    By Down&Dirty in forum Waterjet General Topics
    Last Post: 03-17-2011, 01:44 AM
  2. Calibrating for holes?
    By DragonSteel in forum Mach Software (ArtSoft software)
    Last Post: 12-22-2010, 06:44 AM
  3. Z-axis stopped moving while calibrating
    By Charles2 in forum Bridgeport / Hardinge Mills
    Last Post: 11-27-2010, 09:51 AM
  4. Help calibrating z-axis
    By sp8zzz2 in forum Calibration / Measurement
    Last Post: 08-18-2009, 02:03 AM
  5. Calibrating
    By ikkedus in forum Hobby Discussion
    Last Post: 04-23-2004, 04:57 PM
