Hello,
I am experiencing a problem when I post g-code to mach3. I keep getting a g1 command that includes the z axis, which means I plunge the z along the length of each cut rather than plunging to the cut depth, then making the cut. This problem happens for each chain.
I am using the free trial version of lazycam and a fully licensed version of mach3. Is there a setting in LC that will correct this, and if not, will the problem go away if I purchase LC? I don't want to purchase it if I can't correct the problem.
I can post samples of the code if that helps.
Thanks!
