If you want to change the tool or part offsets you can do it three ways that I know of.
1. Set them by touching of tools or part edges and hit tool or part off set measure.
2. To add or subtract to a number that is already entered, such as adding (1.0) or subtracting (-1.0) write it then hit the write key. (The same key you enter code into MDI with)
3. To enter your own specific number, enter the number such as 10.9765 and then hit the F1 key. This will change whatever is entered to what you enter.
So, with the write key you can add or subtract and with F1 you can enter your own number.
Just as an example, if you need tool one to go .001 deeper, you can add .001 to the tool offset with the write key, or you can add it to the wear adjustment for that tool.
Mike
P.S.: I would recommend being careful with adding your own numbers and make sure you single block your first programs and have the rapid set to 5%. It is very easy to enter the numbers wrong!
