587,070 active members*
3,318 visitors online*
Results 1 to 20 of 44
Hybrid View
    Jun 2010
    28
    G0704 Motor replacement
    I just blew my second motor a few days ago. A replacement is already ordered and I found out today that it is back ordered until "around" April 27th. I need another motor so I can stay productive in the meantime.
    What about this motor as a replacement?
    McMaster-Carr
    Particularly the NEMA 56C C-Face-Mount AC Motors 1hp version #6135K57
    I'm a little unsure on the amp rating and the rpm as the motor supplied from Grizzly specs:
    1 HP (though probably substantially less in reality)
    110V
    Single phase
    3.2 Amps
    5300rpm
    60 Hz
    The motor I'm interested in McMaster is rated at (Full Load Amps?):
    12.0 Amps
    3450 rpm
    Will I burn down the machine, my house and the neighborhood with that higher amp rating?
    Will I get the rpm's at the spindle I'll need or will I have to gear up the motor?
    Can the speed be variable as with the original motor?
    Obviously I don't know much about electric motors except that I need a new one and do not want to wait until the end of April for Grizzly to send me my third replacement only have it take another crap on me.
    I've looked at Hoss's recommendations and either they are over my head technically, shot down by other members for various reasons, too expensive for what it is and from where they are sourced from and no way in hell am I buying used electronics on eBay.
    Any other recommendations/input would be greatly appreciated. I'll name my next project after you
    -Dave
    Aug 2009
    223
    I would love it if someone found a good solution built entirely of reliable and easily sourced parts like motors from mcmaster. That would make my day!
    Ian
    It's an AC motor, the mills controller is DC and it's a 56C frame, it's a huge motor as I showed on the website.
    You could hook up a simple on/off switch for AC power and have 2 speeds with the hi/low selector.
    Hoss
    Jun 2010
    28
    Quote Originally Posted by hoss2006 View Post
    I missed the link to the actual motor on that part of your site.
    Aren't all 3-phase motors 220v?
    So to have variable speed control, the motor has to be DC or run with one of those VFD's if it is going to be AC?
    That may be a bit more than I want to tackle at this point.
    Hoss
    That would suck. :drowning:
    -Dave
    Mar 2010
    Quote Originally Posted by RX-Heven View Post
    No they're not. Dual voltage 220/440 is fairly common, but there's other spec's including 200V(Japan market - but you'll see them on ebay), 575V and others.
    I'm no authority, but I didn't see anyone else pick up on this question.
    Patrick
    24223
    Quote Originally Posted by Papa Foxtrot View Post
    Patrick
    Canada is predominately 575v.
    Usually 220v motors can be picked up relatively cheap here.
    Al.
    Jun 2010
    28
    Patrick
    Thanks for picking that up.
    I can't run 220v for the mill as I'm limited to your standard 110v wall outlet. Then I noticed while reading about one of those VFD's Hoss lists that you can input 110v and it will output 220v for the appropriate motor. The Hitachi VFD linked above does not seem to do that and does not appear they offer one that does.
    -Dave
    Dec 2010
    90
    I'm looking at the Teco EV micro VFD. Input is 110, and it is a vector drive. They have an on-line manual, which is nice. They only go up to a 1 HP drive, tho.
    Here's a link:
    http://www.wolfautomation.com/Produc...roductID=28926
    Mar 2010
    I just picked up a TECO Micro Drive from Wolf Automation. Mine's a 220V input unit, but they have one in 110V. Price is reasonable, but that 110V unit is gonna' pull a pretty good load on your circuit. The 1HP version requires 18A, so you'll need at least a 20A circuit.
    Patrick
    Aug 2009
    223
    Or perhaps a 6135K79 1hp 3phase, and a VFD for it:
    http://www.driveswarehouse.com/Drive...0-007NFU1.html
    Ian
    Aug 2009
    223
    actually, the more i'm reading up on this setup, the more I'm liking it. Those hitachi VFDs look pretty nice.
    The two 1hp 3-ph motors that mcmaster have are 2-pole and 4-pole. The 2-pole is listed as 3450rpm, the 4-pole as 1725rpm. That'd be on 60hz 3phase.
    The VFD will put out 0.5hz - 400hz. 0.5hz on a 2-pole would be 30rpm, or 15rpm on a 4-pole. The VFD manual claims it makes 100% torque at 6Hz, which'd be 360rpm or 180rpm.
    400Hz would be 24krpm on the 2 pole and 12krpm on the 4 pole.
    I'm thinking that 180-12,000rpm is a pretty decent range to have full torque available!
    All in all, not a bad setup for under $400!
    Ian
    7063
    Quote Originally Posted by tmbg View Post
    I don't know about you, but I would not want to be anywhere near any 60Hz motor that's being run at 400Hz (even IF I had one of those big padded suits the bomb disposal guys wear....)
    Ray L.
    Aug 2009
    223
    400hz is probably overkill, but the drive'll do it
    Ian
    Dec 2010
    90
    The drive will put out 400 HZ, but will the motor take it without overheating, and will the bearings on the motor withstand that kind of speed? Also, it is my understanding that when you overspeed motors, you start to lose torque above the rated speed.
    As to torque, the Hitachi VFD listed below is a V/F type drive. It does give constant torque, but that doesn't equate to constant power. Power is torque x rpms. At lower rpms, you will have less power. A sensorless Vector drive will give you better power at lower rpms than a V/F drive, down to about 30 percent of rated speed, I am told. A closed loop vector drive will give you better power at even lower speeds, but introduces a complication, because you need feedback from the motor.
    7063
    Quote Originally Posted by paulsv View Post
    Bearings and overheating are the LEAST of the worries. At those speeds, you have to be VERY worried about the motor exploding, due to the centrifugal force causing the rotor to come apart.
    Ray L.
    Aug 2009
    223
    Quote Originally Posted by HimyKabibble View Post
    Ray L.
    So how fast can you spin one?
    What motors are you SUPPOSED to use with a 400Hz VFD?
    Ian
    7063
    How fast you can go depends on the specific motor. You have to get the specs from the manufacturer. Some motors are designed for 400Hz operation, most will not be, and I very much doubt ANY 60Hz motor will be safe at anywhere near 400Hz. Most 60 Hz 3PH motors seem to be OK up to 120Hz.
    But the centrifugal force increases with the square of RPM, so 2X the speed means 4X the force. Going from 60Hz to 400Hz is almost 7X the RPM, or 49X the force on the rotor. NO 60Hz rated motor is going to withstand that, and when electric motors let go, they can and will quite literally EXPLODE like a bomb, and can very easily do at with more than lethal force.
    Ray L.
    Dec 2010
    90
    Well, you are supposed to run them at the rpm's and amperage shown on the nameplate, If the motor has a service factor greater than 1.0, then the manufacturer is saying that they can occasionally be run at numbers derived by multiplying those numbers by the service factor. That is the rpm that the motor was designed to run at. If you run it faster, it will run hotter, and wear more quickly. Some folks choose to make that tradeoff. Before I overspeed my motor, I plan to check what kind of temperatures it runs at at rated speed, compared to the maximum temperature rise specified by the manufacturer, and not overspeed it beyond that temperature. There are other alternatives to get more rpm if that is what you want, by changing gearing.
    24223
    If you look at high rpm, >22krpm 3 ph motors, they are much smaller in diameter than a regular 60hz frame motor, and are usually air or water cooled.
    Al.
    24223
    4 pole motor @ 400hz = 12,000 rpm on a motor designed for 3600!
    Al.
  1. Another failed G0704 motor controller
    By SgtSpyder in forum Benchtop Machines
    Last Post: 07-03-2017, 02:34 AM
  2. G0704 MOTOR OUTPUT SPEED?
    By fragger6662000 in forum Benchtop Machines
    Last Post: 01-03-2011, 10:46 PM
  3. G0704 Motor Problem
    By mrcodewiz in forum Benchtop Machines
    Last Post: 11-14-2010, 02:47 PM
  4. G0704 Is it normal for the motor to smoke ?
    By evo803 in forum Benchtop Machines
    Last Post: 09-29-2010, 03:20 PM
  5. Replacement Motor Brushes For Sherline Mill AC Motor
    By Lessons in forum Benchtop Machines
    Last Post: 07-17-2010, 02:34 AM
