Hi I have a mazatrol m plus on a vtc 20 b, when it does a tool change it moves in x and z at the same time, this will be a crash at some point, how do I change it so it goes in z first then in a x move. any help please.
give the clearance after the operation is done move the z axis away from component and the move x axis and then give tool change
What control and are you programming in Mazatrol or EIA?
It's just a part..... cutter still goes round and round....
ATC move set to 1 instead of actually 0 in the common unit (unit 0)
no ?
