586,570 active members*
3,671 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > Need software advice...What software can import .JPG files?
Results 1 to 8 of 8
    Jan 2011
    9
    I'm getting ready to buy my first 3 axis CNC machine and need a little advice. I'm primarily using the machine to make intricate drawings on canvas by using a pen instead of an engraving bit but I do plan on doing some engraving and eventually some prototype development of small items I designed. I am looking for software that will allow me to import .jpg files and convert them to g-code. What do you recommend?
    Feb 2009
    2143
    MicroCarve v4
    Home
    May 2011
    test
    Mar 2008
    454
    I recently started using artcam and it will import jpg, I engraved a Honda logo from a pic grabbed from the internet for my first test. ArtCAM is actually a bit too easy to use, I use it for simple pic engravings... but it is lacking in some of the advanced features.
    Dec 2007
    496
    Artcam?
    Mar 2008
    3655
    Artcam:
    ArtCAM - Artistic CADCAM Software: ArtCAM Pro, ArtCAM JewelSmith, ArtCAM Insignia, ArtCAM Express
    [nomedia="http://www.youtube.com/watch?v=i74WCwKUhJ0"]YouTube - ‪ArtCAM - Modelling a Dogs Head from an Image- ArtCAM Pro‬‏[/nomedia]
    CR.
    http://crevicereamer.com
    Too many PMs. Email me to my name plus At A O L dot com.
    Mar 2008
    454
    I didnt have to go as complex as the dogs head video... In that video he opens a new model and starts building by using the dogs head as a stencil.
    But artcam actually has an "open JPG for relief" next to 'new/model'... If you use that feature instead of new/model, it will create a model from the JPG automatically.
    I simply set the work area size, adjusted the Z-height, define stepdown and did a little smoothing.
    Took about 10 minutes total on my first use to produce good GCode.
    The only thing I didnt like, there is not an option for 'keep Z Axis down', so the tool retreats to the safe height every time before going to next Z stepdown... but since I do not have a vacuum shroud around my spindle and have to manually suck up all the shavings, I find the retract time perfect for doing just that.
    I like a program called Img2CAD. Here is the link to their home page:
    Img2CAD converts jpg to dxf,jpg to dwg,bmp to dxf,jpeg to dxf,jpeg to dwg,tiff to dwg,tif to dwg
    This program will scan any type of picture to a DXF file which you can then, using any CAM program such as CamBam, turn into G-Code.
    It is a really neat program that works very well.
    George
  1. Grid, files, other software
    By james45667 in forum BobCad-Cam
    Last Post: 02-22-2011, 08:03 AM
  2. Which software to trim .stl files?
    By Faber.sum in forum Uncategorised CAD Discussion
    Last Post: 06-12-2008, 06:42 PM
  3. Which software to trim .stl files?
    By Faber.sum in forum Uncategorised CAM Discussion
    Last Post: 06-10-2008, 06:24 AM
  4. Software to renumbering G-code files
    By anorec in forum Visual Basic
    Last Post: 02-01-2007, 07:33 PM
  5. scanner software to export dxf files
    By morsee in forum Mechanical Calculations/Engineering Design
    Last Post: 11-01-2005, 05:20 PM
