586,393 active members*
3,169 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > ramping problems in multi tool rough
    Jul 2007
    41
    Somtimes in a multirough 3d part featurecam wants to plunge the tool into a place where it should not. We have the tool set as a non-centering tool and ramp to depth is on, witha ramp angle of 2 degrees. The program will still plunge into an area where should not go. Was there a minimun ramp distance attribute in earlier versions?
    Jun 2005
    69
    have you tried setting a plunge point or "check surfaces" to not cut?
    Jul 2007
    41
    ramp problems
    We contacted delcam and their solution was the rapid stepover attribute in the milling, I don't understand why that effects it, but it does. With the rapid stepover unset, the tool will plunge into places where it should ramp, or not go at all. I set the rapid stepover to .001 and the tool ramps when it should. I also found that using old code option works, without changing rapid stepover, found that out on my own. It's just funny how it worked in the older version code and know you have to watch the rapid stepover. This had nothing to do with check surfaces.
    Tom
  1. Looking for a suggestion for a multi-pocket-tool.
    By slashmaster in forum Benchtop Machines
    Last Post: 07-19-2009, 11:49 AM
  2. Problems with rough finish
    By 44-henry in forum Tormach Personal CNC Mill
    Last Post: 06-02-2009, 06:43 PM
  3. Multi-DNC to Fadal Problems
    By GuitarEng in forum DNC Problems and Solutions
    Last Post: 08-10-2007, 04:40 PM
  4. Double Rough Cut problems
    By inthezone in forum FeatureCAM CAD/CAM
    Last Post: 08-02-2007, 06:12 PM
  5. ' 04 VF 4 Rough Tool changing
    By active-precision in forum Haas Mills
    Last Post: 09-26-2005, 01:56 PM
