Is Aspire able to combine both methods?
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
If you have VCarve Pro and Cut3D (or even the VectorArt3D app) you can import the 3D machining toolpaths into VCarve Pro. I will say however, that I had never tried this myself.
Hello, I have found the vetric cut2d to be a good program and is very simple to use with pretty good features. I emailed them on the "trimming" options and there are ways you can trim the nodes. For the money, it is a good program and I like it's user/interface set up.
I am a MC user since v286 and also a Vectric user . Vectric is by far the best bang for the buck and better tech support to boot.
