586,795 active members*
2,424 visitors online*
Thread: OKUMA LC20
    Feb 2011
    OKUMA LC20
    Hello,
    We have an Okuma LC-20 that can not move past any spindle on command in any program. We believe it is because the spindle does not reach the set speed, usually reaches 80% and fluctuates from there. We have tried from 1 rpm to 1000, spindle override, G50.....we are out of ideas. Any feedback will be appreciated.
    :violin:
    Feb 2009
    6028
    What control. Makes a difference on hardware.
    Feb 2011
    Talking Reply
    OSP5000L-G
    Also, dual turret with a C-axis, simulturn. We are able to jog the C-axis but can't activate the spindle. We get an error code when trying to turn on the spindle, I will look it up 3/3, our next class meeting.
    Can you recommend any areas for maintenance, how to manual:cheers:, sites for parts purchasing. The machine hasn't been operated for 5 years.....warm up cycles/times? Example programs/parts?
    Mike
    :stickpoke:wee:
    Mar 2009
    1982
    how is that?
    it would be easier to advice you knowing the error message.
    Dec 2008
    3113
    You have a variety of problems.
    The main one being inexperience with the machine and control
    Many times, things will not do what is asked, because a condition has not been met
    eg. the spindle may not run because it is still set to zero RPM, yes it will jog at a default RPM, but will not spin.
    Try a MDI --> G97 S100 M3 <write> cycle start
    and then see what happens.
    We cannot see the machine and how you operate it.
    you will have to say what you did, what the machine did/didn't do, the full alarm message - not just the number.
    Also check the "Diagnosis" page for any additional messages, these can point you in the direction of any possible fault.
    Mar 2011
    start with the basics
    do you have chuck clamp confrimation?
    if yes then try this :
    DATA INPUT (i believe its F1 on the OSP5000)
    (without data input you will get an alarm)
    G97S500M3
    WRITE
    CYCLE START
  1. osp 3000 for an lc20 okuma
    By gmsmachinists in forum Okuma
    Last Post: 11-25-2014, 02:20 PM
  2. okuma lc20!help me please
    Last Post: 11-17-2009, 04:23 PM
  3. Replies: 2
    Last Post: 11-26-2007, 04:33 AM
  4. Removing Drawbar - Okuma LC20
    By cmason in forum Uncategorised MetalWorking Machines
    Last Post: 06-06-2007, 08:34 PM
  5. Okuma LC20 Alarms?
    By Eighteenten in forum DNC Problems and Solutions
    Last Post: 04-02-2007, 11:12 PM
