586,762 active members*
8,461 visitors online*
    Jan 2004
    63
    Talking CNC Machine Build
    With lots of inspiration from here, and lots of help I have started a machine build. I have attached the start to the design I have commeitted to. Uses MDF for the machine structure and bearing skates that will ride on aluminum angle. I have been a member for awhile, but this will be my first build.
    I use autocad version 2002 and BobCad v20 to program my stepfather's HAAS VF3, which will certainly come in handy for this build.
    I was thinking of: Stepper Driver and Electronics for CNC Routers
    3 Axis Electronics Combo - $390.00
    (3) 425 oz-in stepping motors
    (3) Drivers (3.0Amp 24-40 Volts, 1-1/64 microstepping)
    (1) 36v 8.8a Power Supply
    (1) Breakout board
    but also looking at:
    3 Axis Electronics Combo (For Heavy Gantry) - $460.00 (New Low Price!)
    (2) 425 oz-in stepping motors
    (2) Drivers (3.0Amp 24-40 Volts, 1-1/64 microstepping)
    (1) 651 oz-in stepping motor
    (1) Driver (6.0Amp 24-70 Volts, 1/2-1/256 microstepping)
    (1) Breakout board
    Thinking the ganty may be heavy and might be nice to have the extra juice for the x axis.
    Open for suggestions!!
    Attached Files Attached Files
    Try not. Do. Or do not. There is no try.
    Jan 2004
    63
    I already see some design issues, but wanted to start this thread. The dashed lines in the drawings were meant to show the travel. I see there will need to be some dimension change in the x axis.
    Aug 2005
    437
    Good luck with your build, I'm sure you will enjoy it and learn alot... I know I did.
    V&B
    Deeds not words...
    VoltsAndBolts runs RC for the builder. http://www.voltsandboltsonline.com/ My Forum
    Jan 2004
    63
    I made some changes. I would like to be able to cut a 4x4 sheet of material, so I plan to use a 5x10 sheet of mdf for the base. I can order it though my local lumber yard. I also offset the ganty so I don't lose so much travel due to the width.
    Someone chime in on the size. Do you think this is too big for mdf to handle?
  1. New Machine Build
    By Sforzarsi in forum Education - Teachers and Students Hangout
    Last Post: 05-11-2010, 02:29 PM
  2. My first machine build
    By Sendo in forum DIY CNC Router Table Machines
    Last Post: 07-12-2008, 12:42 PM
  3. New machine build under way.
    By EL34 in forum DIY CNC Router Table Machines
    Last Post: 02-20-2008, 01:41 PM
  4. Looking to build a CNC machine
    By mitchDM in forum DIY CNC Router Table Machines
    Last Post: 11-05-2007, 01:06 AM
  5. Use the second machine to build the first!
    By Madclicker in forum CNC Wood Router Project Log
    Last Post: 06-27-2007, 05:29 AM
