586,437 active members*
3,851 visitors online*
    Mar 2006
    255
    Question Curious: 32bit and 64bit
    Hi all,
    Just a quick yes or no type question.
    Can files saved on one format of Solidcam, i.e. 64bit open on a 32bit version, if the version year is the same or later?
    Reason, I'm thinking of updating the whole system to 64bit, so do not want to have to recreate everything.
    pinguS
    Feb 2007
    505
    Exclamation
    Quote Originally Posted by pinguS View Post
    Hi all,
    pinguS
    Not sure about your question , but if you run Mach 3 it wont work with 64 bits.
    Software Requirements
    Keeping with our home hobbyist roots, the minimum software requirements to run Mach are very reasonable. Below are the specifications for running Mach3 stably.
    Mach3 Minimum Requirements:
    Desktop (using the parallel port)
    ◦32-bit version of Windows 2000, Windows XP, Windows Vista, or Windows 7 Operating System (64-bit will not work)
    ◦1Ghz CPU
    ◦512MB RAM
    ◦Non-integrated Video Card with 32MB RAM
    ◦Basic Computer Skills (ability to copy/rename files, browse directories, etc)
    Mar 2006
    255
    No, this is for CNC machines with fanuc control etc, not that it matters as the computer post suits the machine after. It's just to open my 32bit manuctured files on 64bit system, was wondering if there is any problem
    Oct 2007
    499
    As far as I understand, files create by the same release e.g. SC 2010 etc. can be opened by either 32 or 64 bit software. This is certainly true of SolidWorks because that happens here every day
  1. Epilog lasers do not work with Corel Draw in Windows 7 (64bit)
    By jeanyes in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 07-27-2010, 04:21 PM
  2. curious....
    By pulsar110 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-29-2007, 11:33 PM
  3. Camworks 2007 on a 64bit Windows
    By Andreas0815 in forum CamWorks
    Last Post: 09-28-2007, 01:50 AM
  4. Just Curious
    By weimedog in forum FeatureCAM CAD/CAM
    Last Post: 03-20-2006, 06:27 AM
