586,465 active members*
3,588 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Problem - Pendant Link Failure
Results 1 to 11 of 11
    Nov 2010
    We posted a few weeks ago regarding some general problems with the Arrow 1000 having some random and untraceable issues with stability. We cleaned all the boards in the PC and the system is now very stable. However, we are still encountering a primary pendant link failure every so often, usually when the pendant is being handled.
    Any thoughts as to what the issue could be?
    Thanks.
    Oct 2008
    123
    primary link fail
    hello my experiences would suggest that you have a connection problem with the pendant. i would suggest seperating the pendant face plate from the black body of the pendant ( remove the six screws and pull it apart ) and checking the internal connections. it is possible that you have a damaged case and that the damage is allowing the pendant to flex and causing the primary pendant link fail. if there is no damage and no loose internal connections then you are left with no other option than to change the pendant
    regards
    mallardfizz
    Nov 2006
    418
    Ditto on mallardfizz's recommendation! I've had this same problem for 2 years or more now, and have gotten that same diagnosis from many sources. As of yet it hasn't stopped me, it just takes a while to get the machine started (when I do shut it off, which isn't very often...).
    The rebuilt pendant is over $2500 as I recall, so we're holding out until we have no choice (not my decision).
    Rgds,
    John B
    Feb 2011
    423
    I just started having this problem last night and think it may be in the cable between the pendant and the monitor.
    Mar 2011
    Heinster
    You might try updating the diagnostic s/w in the control before ordering any parts. Contact the tech support group at Siemens - they can e-mail it to you. Hot Line#800 879 8079
    Jul 2013
    HELP ME
    Primary Pendant Link Fail.
    Cause: The communication link which connects the primary pendant to the control has failed with the following error. The MSL detected an analog to digital converter failure returned by bbbcfg.
    Remedy: check that cables are properly plugged in and appear to be.
    Feb 2011
    423
    Can you borrow a pendant from somebody to see if that fixes the problem? IIRC there are two different type connectors. Every once in a while you can find one on Ebay for around $1K.
    Jul 2013
    I had one that would not start when switched appeared that alarm. So it may be that the pendant is not compatible with the machine?
    Jul 2013
    7
    wait for the update....
    Jul 2013
    takes to update?
    Apr 2009
    32
    I had received same alarm once couple of weeks back. In my case the problem was due to winding cable connecting the pendant and monitor.
  1. RS232 link problem on CL200 with M64 Controller
    By rkucbel1 in forum Mori Seiki lathes
    Last Post: 12-14-2016, 08:29 PM
  2. MDI / RAP failure
    By s&swelding in forum Cincinnati CNC
    Last Post: 04-30-2010, 07:24 PM
  3. Replies: 0
    Last Post: 01-27-2009, 07:18 PM
  4. cad link problem
    By helix77 in forum EdgeCam
    Last Post: 07-10-2008, 07:38 PM
