586,437 active members*
3,927 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > HITACHI SEIKI 3NE 300 LATHE ALARM 401
    Dec 2010
    Hi my names Jordan
    I was looking to grow my small engineering firm by going down the turned parts road. I have recently purchased a Hitachi Seiki 3ne 300 lathe with fanuc t6 controls. I was told there where a few niggles with this lathe hence it being free from a friend who was going into liquidation. Now I have had it wired in and when I power it up it says not ready (i know this normal). The next thing on the screen when pressing the standby button is
    U 0.000
    W 0.000
    00012 N0012
    Also I know this is normal.
    But next when i move the turret on the x axis on the joy stick all is fine but as soon as i move the y axis theirs a clonk and alarm code 401 servo.
    Any ideas whats doing this i have
    Thanks Jordan
    Attached Thumbnails Attached Thumbnails 2011-02-15205638.jpg   2011-02-15205655.jpg   2011-02-15205807.jpg
    Dec 2010
    or any one know an engineer that might i can get to have a look
    Apr 2005
    175
    401 Alarm caused by binding in shaft assembly for axis used. Try to see if axis will move with hand rotating (binding ball screw?). If nessessary, remove servo and try to rotate shaft to move y (binding of any means will trip this code) If shaft moves freely, try to signal servo and see if it rotates..... PM me and we can go to next step
  1. Hitachi Seiki Alarm Help!
    By stevo1 in forum Controller & Computer Solutions
    Last Post: 12-11-2021, 09:47 AM
  2. HITACHI SEIKI HT-20 Lathe?
    By stealth1 in forum Mach Lathe
    Last Post: 01-10-2011, 09:17 PM
  3. Hitachi Seiki HG630 II Alarm 2237
    By Jim Green in forum Mori Seiki Mills
    Last Post: 08-18-2010, 06:30 PM
  4. hitachi seiki 4ne-6t M05 motor alarm
    By scooter g in forum Vertical Mill, Lathe Project Log
    Last Post: 07-20-2010, 05:17 PM
  5. Hitachi Seiki alarm code help
    By atrus in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-29-2008, 03:49 PM
