586,388 active members*
3,262 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > How to set a negative value in THC Min (Mach3)
    Sep 2005
    287
    Hi Everyone,
    Does anybody know how to set a negative value in THC Min. THC Max is not a problem because I don't need a plus sign in front.
    However for THC Min, I type in a value with a negative sign in front but when I press enter there's no negative sign so I'm assuming Mach looks at it as a positive value.
    Keith.
    Jul 2005
    2415
    If you are using the latest screen set (circa 1/8/11 or later) then the THC MIn setting in the Settings tab was not made wide enough in the screen set and does not display the "-" sign on the left. It's there and the value is stored correctly in MACH. I am going to do a minor screen update of that screen set (just make the DRO's one character wider) and put it up on the CandCNCSupport Yahoo forum.
    I gave you a quick fix (manually edit the XML file) on the forum but then realized you don't really need to do that since it's a display issue not a settings issue.
    TOM caudle
    www.CandCNC.com
    Sep 2005
    287
    Hi Tom,
    I just sent you a reply on the Candcnc Yahoo group, pretty much saying that's what I found. I often post on CNCzone too due to the time differences between the US and Australia, in the hope I may get an answer to my problem on the same day.
    Once again thanks for the prompt support.
    Keith.
  1. Negative Molds
    By schllac in forum Moldmaking
    Last Post: 12-04-2010, 05:57 AM
  2. DRO shows negative
    By CJCNC in forum Syil Products
    Last Post: 07-03-2010, 12:12 PM
  3. Negative Buttress
    By byrdo in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2010, 01:47 PM
  4. 5 volt positive and negative??
    By Rooney in forum Automation Technology Products
    Last Post: 05-07-2009, 10:04 PM
  5. G83 + G72 with negative return plane
    By drewmeister in forum Haas Mills
    Last Post: 02-21-2007, 01:21 AM
