586,655 active members*
2,070 visitors online*
    Nov 2010
    ML17 oiler meters?
    Where do I purchase (besides milltronics) a set of meters for my ML17. Apparently, one of them was installed backwards and my x way was receiving no oil for some time now. . .
    I might as well replace them all while I'm at it.
    tHANKS
    Nov 2010
    Also,
    looking to replace the x way felt covers. Milltronics says they are 'discontinued'. Any ideas?
    Jan 2007
    89
    Check a dealer that carries Bijur stuff.
    The oiler on our Partner4 is a Bijur. IIRC the oil restrictors are separate from the check valves.
    Felt covers? Try some felt and a pair of scissors, or a razor knife.
    McMaster Carr should be a good bet for both. The Felt, that is, not the knife or scissors.
    MSC? Acklands?
    Cheers
    Trev
    Nov 2010
    Alright,
    I found these guys:
    http://www.industeq.com/stock/listings.asp?manuId=17
    A good source as they only charged about $10 each meter vs. $17-25 that everyone else wanted.
    Yeah, I figured the cut-a-felt method would be the one that makes the most sense. THANKS,
    -dustin
  1. Haas hour meters???
    By mniadna in forum Haas Mills
    Last Post: 03-26-2015, 02:35 PM
  2. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
  3. Axis motor load meters?
    By davesnd in forum CamSoft Products
    Last Post: 11-10-2008, 07:58 AM
  4. Panel Meters
    By beausdn in forum Gecko Drives
    Last Post: 08-12-2005, 05:35 AM
  5. Axis load meters?
    By DAB_Design in forum CNC Machine Related Electronics
    Last Post: 10-14-2004, 02:35 AM
