586,776 active members*
8,707 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas 4 axis - controller displays rapid on a feed move
Results 1 to 11 of 11
    Feb 2011
    I am having some surface finish problems when cutting with simultaneous 4 axis. I noticed that when there is a lot of rotary motion in my program the controller flashes between feed and rapid on the display, but each line of code has a given feed rate, there is no G00 call.
    Anyone have any ideas on this?
    Aug 2010
    579
    Are you using inverse time?
    Ken Foulks
    Feb 2011
    Yes, G93. But even when turning that off, it still shows the same thing.
    thanks for the reply,
    Jim
    Aug 2010
    579
    Is HSM enabled?
    Ken Foulks
    Feb 2011
    Yes
    thanks,
    Jim
    Dec 2010
    154
    Did you tell the control what diameter you are working at so the feed can be correctly calculated? I believe the diameter call out is the next parameter below "4th axis enable"....
    Feb 2011
    Yes, the diameter has been set.
    As a result of another error, i had to restart the control. The rapid/feed display seems to be solved by the reboot. I am still having finishing problems, but that doesn't seem to be related.
    thanks for all the posts in reply!
    Jim
    Jan 2011
    see rapid while doing only feed
    What you are seeing is an efect of mixing linear and rotary motion with high speed machining option. it is not a problem. It just indicates that the rotary axes had to slow down when getting near the end of a stroke to insure machine stays accurate.
    Feb 2011
    That's very interesting. I'm doing some tests that show just that. The rotary is ahead of the linear axis on each move, but I'm starting to think it is a problem.
    Anyone found a way to tune the rotary axis to the linear?
    Jan 2011
    shows rapid during feed
    Check that parameters 786, 787, 788, and 789 are all the same value. If you have them, they are probably set to 64 but they all need to be the same.
    Feb 2011
    Wizard of H - cannot thank you enough....and Haas should thank you too. Seems they've shipped their version 17.03 software machines with the linear FIR's set to 64 and the Rotary FIR's set to 0. Linear and Rotary axis are tracking much better now with both set to 64.
    thanks so much,
    Jim
  1. Okuma mill feed rate jumps to rapid feed
    By easyguy97 in forum Okuma
    Last Post: 12-20-2009, 11:14 AM
  2. Rapid move axis control
    By mattpatt in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-15-2008, 03:51 PM
  3. Haas rapid move ?
    By binzer in forum Haas Mills
    Last Post: 06-29-2007, 01:11 AM
  4. Crash during Z rapid move
    By AndyB in forum Fadal
    Last Post: 03-07-2007, 03:48 PM
  5. Axis move during feed hold
    By 1ctoolfool in forum Haas Mills
    Last Post: 09-12-2006, 04:12 PM
