586,983 active members*
3,420 visitors online*
IndustryArena Forum > Hobby Projects > Musical Instrument Design and Construction > Counterboring Tele String-Through Ferule Holes?
Results 1 to 5 of 5
    Mar 2006
    168
    Just wondering how this is done. I had one shop say they had a 3/8" bit turned down to 5/16 up to the depth of the ferule and let the 3/8" diameter cut the counterbore. But I'd think there's already made for this application. What do you use?
    Aug 2006
    133
    Try industrial supply places like McMaster.com, mscdirect.com, use-enco.com, american-carbide etc. They have counterbores, long-reach 1/8" end mills etc. All kinds of good stuff. Metalworking industry stuff. Vortextools and precisebits have good specialty stuff. Prices vary so look around.
    Aug 2006
    133
    For tuners like Grovers I drill for the shaft using an endmill, 1/4 I think, and then I do a clean-circle (helix) operation to cut the larger counterbore for the tuner body. A few times I've had to drill as deep as I could with the bit I had on hand and then use that hole as a guide on the drill press to finish it out. I don't do tele's so I can't help with that. Ed Hawley has a really in depth thread somewhere here where he does a very detailed cnc build of an Esquire or tele. Check that out.
    Apr 2004
    177
    Buy a step drill from a place like Harbor Freight. it goes 1/4-5/16-3/8-7/16 etc in steps.
    Apr 2004
    177
  1. Tele cad drawings
    By Bdfamily in forum Musical Instrument Design and Construction
    Last Post: 02-06-2019, 11:40 PM
  2. 18T dowload to pc no eob just long string
    By karlbushnell in forum Fanuc
    Last Post: 01-28-2011, 02:55 PM
  3. Zap String
    By Aplus in forum Bridgeport / Hardinge Mills
    Last Post: 11-04-2009, 05:01 AM
  4. Newbie needs help-counterboring
    By mikemechanic in forum MetalWork Discussion
    Last Post: 12-28-2007, 06:20 AM
  5. Counterboring carbide ?
    By DEVOR in forum MetalWork Discussion
    Last Post: 11-02-2007, 06:14 PM
