586,832 active members*
3,053 visitors online*
IndustryArena Forum > CAM Software > CamBam > Start Point to Mach3
    Mar 2006
    38
    When I enter a Start Point for Part 2 it does not transfer to Mach3.
    Help will be appreciated.
    Thank You
    Grandpa Jay
    Feb 2005
    521
    Start points are set for individual machining operations by right clicking the machining operation then selecting 'Set start point'.
    When you regenerate the toolpaths for that operation, you should see the yellow direction arrows move closer to the start point (the arrows are displayed on the toolpath start points).
    The start point is only a hint for the first toolpath start point for the machining operation. After that it will move in turn to the next nearest toolpath point as part of the optimisation.
    If this doesn't help, feel free to upload a file so we can see better what you are trying to do.
    Quote Originally Posted by grandpa jay View Post
    Thank You
    Grandpa Jay
    www.cambam.co.uk
    Mar 2006
    38
    So it is not setting 0,0,0 for that machining operation.
    Thank You
    Grandpa Jay
    Feb 2005
    521
    The 0,0 point is set in the MachiningOrigin parameter.
    This is set either on the Part object or on the Machining object (which will set the same machining origin for all parts).
    A quick way to change this is to right click the Machining or PArt object in the drawing tree then select 'Set machining origin', then click a point on the drawing. The machining origin is then displayed with a red X icon. This cross can be dragged around to change it's position.
    Thank You
    Grandpa Jay
    www.cambam.co.uk
    Mar 2006
    38
    Thank You, I will give this a try.
    Grandpa Jay
  1. V24, moving start point
    By tome9999 in forum BobCad-Cam
    Last Post: 01-20-2011, 02:59 AM
  2. Use a point for the start point of a profile.
    By dcskid in forum BobCad-Cam
    Last Post: 03-18-2009, 04:31 PM
  3. Setting Start Point
    By Hellbringer in forum Mastercam
    Last Post: 11-24-2008, 05:29 PM
  4. re start point
    By woffler in forum BobCad-Cam
    Last Post: 11-06-2008, 02:56 AM
  5. 2D Toolpath Start Point?
    By mlinder in forum OneCNC
    Last Post: 09-07-2003, 05:28 PM
