586,838 active members*
2,600 visitors online*
    Feb 2011
    6'' Craftsman lathe belt change
    I have a 6inch Crafstman lathe, i want to change the belt witch is almost in half , can anybody walk me thru this procedure?? [email protected]
    Jan 2010
    485
    You can do a search for 6" Atlas lathe that is who made them for Sears. If you aren't trying to just restore it to original, you might consider using these; Grizzly.com® -- Search Results
    The Power Twist is the last belt you will ever have to buy for the lathe. The will transmit more power than a regular Vbelt and you don't need to take the lathe apart to install it. Just cut the old one off and put the Power Twist on.
    Nov 2006
    22
    I'll agree about the power twist belts. I have a 1960 Craftsman lathe and the belt was about gone. I REALLY did not feel like dissasembly of the whole head. I figured that I would give it a try, cut the old belt off, and installed the twist belt.
    It not only worked, but runs smoother and more quiet too. Just do it... you will be glad you did.
    Jerry
    Jan 2011
    12
    sears dunlap lathe belt change
    Hi
    remove the drive gear from the spindle
    remove the two piece coller
    there is a set screw in the drive pulley it should not be tight
    slide the drive pulley assembly to the gear end of the shaft
    there is a very small keyway in the shaft , remove
    slide spindle shaft out
    steve
    Dec 2009
    If you decide to remove the spindle here is a great set of directions.
    http://www.deansphotographica.com/ma...e/spindle.html
    If you have any problems visit the Atlas lathe forum, they are a great group and very helpful.
    http://www.machinistweb.com/forum/forumdisplay.php?f=6
    Bob
  1. Atlas/Craftsman 12' Lathe
    By Jim Ciampi in forum MetalWork Discussion
    Last Post: 11-02-2009, 02:17 PM
  2. Conversion of Atlas/Craftsman lathe?
    By jgourlay in forum Mini Lathe
    Last Post: 08-31-2007, 06:50 AM
  3. Anyone here have a Craftsman/Atlas Lathe?
    By ZipSnipe in forum Mini Lathe
    Last Post: 03-30-2006, 12:08 AM
  4. belt numbers for 6" Craftsman Lathe?
    By shootingarts in forum Uncategorised MetalWorking Machines
    Last Post: 02-09-2006, 03:29 AM
  5. Hardinge Lathe Spindle Belt change
    By Ken_Shea in forum Bridgeport / Hardinge Mills
    Last Post: 09-12-2005, 07:39 PM
