I think the title says most of my issue, but I'll explain further...
I'm trying to test the squareness of my machine. As of now I have not "messed with" the column; it's exactly as it was when I received it. As you can see in the video I set up a dial test indicator against a square positioned close to the table. I then raised the Z 12". ~3.5" up the square the indicator is reading ~6 thousandths off. To me this seems pretty bad. After that it stays within ~1 thousandth (within a thousandth of the reading at ~3.5" above the table which is between 6 and 7 thousandths of the reading just above the table). I hope this makes sense. If not, I think the video does a pretty good job showing what is happening.
Is 6 thousandths over less than 4" acceptable? Any advice on how to fix this?
I'm assuming it's not the square. It's brand new and is suppose to be accurate to within ~2 ten-thousandths at the top.
I'm a novice so if you see something in the video that I'm doing wrong please tell me.
[nomedia="http://www.youtube.com/watch?v=E3CNdoNdu2k"]YouTube - Novakon NM-200s2 XZ plane squareness test[/nomedia]
