586,339 active members*
4,001 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > help for the music, arch top guitar
    Jan 2009
    5
    cant find a way to get this wright , just want to do a profilearound the edge like a router
    Jan 2009
    5
    Is there no one that can help
    Oct 2006
    53
    I'll try
    I'm very new at this, but I would do the following:
    Activate 2D sketch and choose the sketch plane to be the plane that the bottom edge of the is in. Define your profile using the b-spline tool, or whatever, to get a smooth line. Double to line somehow. Make sure the outer of the doubled lines is outside any of the waste of the cut. Then use extrude cut to cut the edge of the top, selecting the doubled lines to extrude.
    I tested this using circles instead of splines, and it worked.
    Couple of pics attached.
    Aug 2008
    386
    You need to join the forum on Alibre's website.
    There are some highly skilled users there.
    Alibre Design User Groups • Index page
    Joe
    Jan 2009
    5
    thanks guys
    I got it closer i will post it when I get it done I had to select one edge at a time and had to put a radius on corners to make work better
  1. cnc Music!!
    By kram242 in forum Mach Software (ArtSoft software)
    Last Post: 04-22-2022, 10:37 AM
  2. X2 arch help
    By Eritex Inc. in forum Mastercam
    Last Post: 11-24-2010, 02:23 AM
  3. Arch Commands Boss 10 Please help.
    By wcarrothers1 in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2008, 05:10 PM
  4. Turbo CNC @ Arch cutting ???
    By Milton in forum OpenSource Software
    Last Post: 08-14-2006, 05:48 PM
  5. Design & Cut Arch
    By krazycnc in forum Uncategorised CAM Discussion
    Last Post: 08-26-2005, 03:06 PM
