I turned on the mill last night and got the following messages on the screen.
Spindle Inverter Fault Detected
Emergency Stop Released
Z Limit #6 Excceeded Limit
When I released the emergency stop the CT1 Relay did not close.
When you hit the cylce start button the nothing happens. The lube pumps don't even run.
After some searching I have determined that the errors detected do not really exist. For instance all the limit switches are closed as they should be.
The emergency stop button is functioning properly.
I also found that if I put all of the limit switch dip switches on the servo board in the up position (bypass) then the emergency stop relay will pull in and I can jog the axis, however nothing else that requires an input will operate such as the spindle will not run.
I am not sure what else to check to determine narrow down and isolate the problem.
Any help would be appreciated. Gary
