Beginning in the first quarter of 2011, Geckodrive will be rolling out some fairly substantial changes. We have put these below so you know what to expect in the coming months:
1.) New Website
We have launched a completely new Geckodrive in the New Year with a focus on being user friendly. We have re-designed our technical support and application note section to be more accessible to all users. There will now be a text version of every single application note on the website with no need to download a PDF version. Our FAQ section has also gotten this treatment and we will be interlinking all relevant technical documents to each product.
The new website will also feature a user forum where we will post news regarding upcoming projects and will provide technical support from Geckodrive staff.
We have also added a language translation feature so customers can translate all pages of the website into their native language. This can be done by choosing the language from the drop-down menu at the top of the Geckodrive website.
2.) International Distributors
In the last few months of 2010 we began to seek out international distributors in countries with a large Geckodrive user base. We feature a section on our new website to show each distributor organized by country with a link to their website. Because all products are kept in the distributor's country all duties and import fees have been paid, making the price they charge the actual cost. This way, customers will not have to pay additional tariffs and international shipping in locations where an international distributor is available.
As always with Geckodrive, international customers will still be able to order directly from Geckodrive if they prefer. Distributors are there for your convenience; however, they will not be the only option our customers have.
You can see our distributors by clicking International Distributors on the drop down from "Products/Order".
3.) Price Changes
Because of components moving to obsolescence, notably the 4000 series of integrated circuits that are used by the original G200 and G300 family of products, we will be changing our prices. The single unit prices of the G203V, G250, G251, and G540 will remain the same. The G201X and the G320X will see a 6% price increase due to rising component costs from most manufacturers; the G201, G202, G210, G212, G320 and G340 will have price increases to reflect the increasing cost to manufacture them.
Price increases are not something we take lightly and are an unfortunately necessary evil. Geckodrive has not raised prices on our products in ten years, in spite of ever increasing component costs. Because this is something we have not done before it is also something we do not plan on doing again for quite some time. The new price schedules are in the attached document and are currently live on the website.
4.) Motors
Manufacturing all motor controls in-house from start to finish has been our main priority since Geckodrive's inception and will remain its primary function in the coming years. We have partnered with Lin Engineering to offer quality, American made, custom motors specifically manufactured to match our motor controls. Lin Engineering manufactures all of their motors in Morgan Hill, CA and they are the perfect balance of linearity and holding torque. We currently offer one NEMA 23 motor meant for use with the G250, G251 and G540, but will be offering high torque NEMA 34 motors for use with our higher power drives in the first quarter of 2011 with further expansion as the year progresses.
5.) New Products
Major Projects:
GeckoMotion:
The major new development effort is designing an embedded motion controller. This is a 4-chip controller using a PIC24F MCU, an ACTEL ProASIC3 FPGA, a 32Mb Flash EEPROM and an RS-485 interface transceiver IC. The motion controller firmware and hardware project working name is GeckMotion and motor drives using this embedded controller use a 'GM' prefix for their project names.
The embedded controller will use ASCII text commands using simple 1 and 2 character mnemonics. The motion control algorithm is an “on-the-fly” type; the rate of acceleration, velocity and destination are all changeable even while the motor is in motion. The motor position is a 32-bit resolution value and velocity and acceleration are 16-bit values. The velocities are 65,536 evenly spaced frequencies (1Hz resolution from zero to 65,535 Hz). The motor phase current, standby current and standby delay time is set via the controller. The controller also includes buffered general purpose digital I/O as well as analog inputs.
The PIC24F executes the motion control firmware, communications interface and bulk axis coordinate storage in the serial flash EEPROM (about 200,000 x,y,z coordinate locations). Constant velocity 3D vector motion is built into the design. The design allows for stand-alone or autonomous operation without a PC being present.
The FPGA is the pulse engine which generates the evenly spaced step frequencies. It also performs the motor drive logic necessary to run a motor, a task presently done by much less powerful CPLDs in our newer existing drives. This serves to eliminate the CPLD and much of the external analog circuitry.
A unique feature of the FPGA pulse engine is it renders microstep resolution meaningless. Motor motion remains monotonic (non-incremental) no matter how slowly the motor moves. The effective 'microstep resolution' of the drive becomes the inverse of motor speed; at very low speeds the apparent resolution measures in thousands of microsteps per step. At high speeds (thousands of RPM), the apparent resolution drops to 4 microsteps per step which keeps the required step pulse frequency very modest (40kHz gets 3,000 RPM). Statically (zero RPM), the resolution is essentially unlimited and measures out as tens of thousands microsteps per step.
The small package sizes for these ICs results in the motion controller occupying only 0.7 square inches of board area. This is small enough to allow the controller to fit on our standard size motor drive printed circuit board. The true CMOS design of the MCU and the FPGA results in a controller drawing a 15mA supply current, well within the thermal design limits of our standard drive's voltage regulators.
GM540:
The G540 has been a run-away success for us. It is a 4-axis microstepping drive designed to interface with a PC parallel port interface CNC program such as Mach3 and EMC2. It is intended to drive NEMA-23 size step motors up to 3.5 Amps and 50VDC.
The first new product will be the GM540. This product will have the current G540 parallel port interface replaced with a GeckoMotion controller. The controller firmware has 1, 2, 3 and 4 axis variants; the GM540 will use the 4-axis firmware with no motor control logic because the GM540 will continue to use our G250 microstep drives internally. The DB-25 connector will be re-tasked to serve as a general purpose I/O connector for axis home and limit switches (SPST switch to GND), 0.5A open drain outputs (IN POSITION output, GO input handshake). The GM540 will be the same physical size as the G540 and will be targeted for industrial applications.
GM201:
The GM201 will be a 7A per phase, 80VDC class step motor drive incorporating an embedded GeckoMotion controller. It will have nothing in common with the existing G201 10-microstep drive except the package size and a similar model name. It will not be a drop-in replacement for the G201 because of its RS-485 interface. Its features are outlined in the GeckoMotion controller description.
Another unique design feature of the GeckoMotion controller will be its ability to synchronize itself with other single axis GM201 drives daisy-chained on the same RS-485 communications link. This synchronization will phase-lock all the drives’ crystal oscillators to allow coordinated motion (multiple axis vector motion) as if the drives were being commanded from a single multi-axis motion controller. A single drive will be set as the RS-485 master and the other drives and the PC (if used) are set as slaves. This synchronization scheme works on paper but is yet to be tested.
GM401 and GM801:
The GM801 will be a brushless DC motor (PMSM motor) servodrive. It will use Field Oriented Control algorithm based on the Clarke-Park transforms and their inverses. The Clarke transforms convert a rotating 3-phase vector into a 2-phase vector while the Park transform converts a rotating 2-phase vector into a stationary reference. The stationary reference is modulated by a PID feedback loop to complete a servodrive signal path. The inverse transforms restore this stationary reference back to a rotating 3-phase vector again. This vector modulates the motor currents via a Space Vector Modulation. The power rating of the GM801 will be similar to our G320 drive, 20A and 80VDC.
The GM401 will be a Field Oriented Control step motor servodrive. It will be a derivative of the GM801; a step motor is natively a rotating 2-phase vector so only the Park transforms and their inverses need to be used. Field-weakening will allow the step servo to achieve reasonable speeds in the 3,000 to 6,000 RPM range.
A step motor has a very useful speed-torque curve in that torque is the inverse of speed. This means the motor can be caused to back up its torque curve when the motor is slowed down. The controller automatically provides a “percentage of available torque being used” signal. An exterior feedback loop can then utilize this signal to intentionally slow the step servo should this signal indicate the torque load is approaching 100% of available torque. In effect the GM401 becomes an unstallable servo; a torque overload results in the motor slowing down and the motor is restored to full speed once the overload disappears. The 'on-the-fly' design of the GeckoMotion controller easily permits this feature.
Minor Projects:
G205X:
The G201X drive has had a redesign which added short-circuit protection, an opto-isolated DISABLE input, an opto-isolated FAULT output (open collector), a red LED indicator for FAULT, a green LED for POWER and a self-test DIP switch setting which moves the motor CW/CCW at 1 rps at a 1Hz rate. The current set resistor option is removed and motor phase current set is via DIP switch only now. Because of the considerable terminal pin reassignments the drive is now called a G205X. Prototypes will be available for in-house testing in 2 weeks.
G901X:
The G901X is a redesigned G901 pulse multiplier with improved performance that is compatible with the G201X, G202X and G203V drives. These drives couldn't use the G901 because of voltage incompatibilities (12V logic on the G901 versus 3.3V logic levels on the aforementioned drives). Prototypes will be tested next week.
We thank you for your loyalty and patience through this transition and look forward to doing business with you in 2011.
Marcus Freimanis
Geckodrive, Inc.
