first time posting ..... I have a bridgeport series 1 CNC but being used manually that I have a question about milling in regards to the Z axis. When I run repeated passes on a part in either X or Y axis the cuts from pass to pass are not consistant on depth of cut. The Z axis ball screw appears to be tight and my readout display for the linear encoder doesn't show any movement. 10 um resolution. Does anyone know this problem and have a solution for it? Is the quill worn out or the ballscrew have play in it I'm not finding or is the attaching bolt from the yoke to the quill loose? I haven't pulled the ballscrew off to check that bolt. thank you for any suggestions.
