586,383 active members*
3,751 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Fillet surface to surface problem
Results 1 to 7 of 7
    Oct 2009
    10
    Unhappy Fillet surface to surface problem
    Hello,
    I don't understand where is my problem.
    here is a file using Two surfaces.
    I only need to do a fillet on the two surface or surface to plan.
    If I set a fillet size of 4mm it give me a correct result but if I set a Value more Than 6mm it could crash mastercam and in better case give me a partial fillet.
    where is my miss-understanding !?
    here is the file :
    http://hchristele.free.fr/T.EMCX-5
    Oct 2009
    10
    no idea of the problem ?
    Dec 2008
    3111
    Surfaces can be temperamental
    it's much easier do do it on the solid, and then create surfaces from new solid, is that available ?
    You are using the X5 educational version (.EMCX-5) , so you should have "solids"
    For filleting or chamfering, a rule of thumb is to work from the larger size to the smallest
    Eg --take a 50mm cube and filet 1 edge R20, and an intersecting edge with R5. Yuo should get get a solution.
    But do it the other way round may give errors, especially on complicated corners
    Filleting and chamfering , quite often foul up on surfaces, I think it depends on "node points" or features that are used to define the surface/s
    Feb 2010
    fillets
    Quote Originally Posted by vincent13 View Post
    if your going to 3d machine don't waste time filleting the solid. just use a ball endmill with a smaller radius. use verify to see simulation. creating fillets on solids or surfaces blows. just avoid all together.
    Apr 2005
    1194
    Surfaces are not tempermental! You need to extend a surface then fillet it if your fillet is not completely filling the gap and the radius is too small. What would mastercam be expected to do when you have more than a 5MM gap and you ask Mcam to do a 5MM fillet radius?
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Oct 2009
    10
    thanks for your answers.
    As I 'am studiing mastercam (in solo mode), I could not be a superman
    - ok, when I arrive to the solid chapter I will redo this exercice
    using solids
    - suppposed to do a circle filet simply ?! .. and not to be able to crash
    by the way I have done this exercice using several step with simplier surfacies.
    thanks all for your advices.
    Apr 2005
    1194
    Alot of people think Mastercam crashes on them they dont read the little yellow dialog box that is asking them to pick a certain entity or do something. Hit the esc key if you think it is locking up.
  1. Flow along a surface problem
    By zonker in forum Rhino 3D
    Last Post: 07-06-2010, 11:49 PM
  2. Surface Problem
    By ZeroDay in forum Mastercam
    Last Post: 10-23-2009, 12:29 AM
  3. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
  4. ?! Please help me with this surface problem.
    By Ben J in forum Solidworks
    Last Post: 09-29-2007, 06:25 PM
  5. Swept Surface problem
    By cijunet in forum Mastercam
    Last Post: 02-18-2007, 04:34 AM
