586,410 active members*
3,036 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Build Log: RMGVideos XZero Raptor Build
Page 1 of 8 123
Results 1 to 20 of 151
    Mar 2009
    388
    About a year ago I was looking for a 2nd CNC router. I have a Shopbot 48x96 but wanted another one that used mach 3. I produce CNC Guitar building videos so I wanted a 2nd machine to create videos based on mach 3 and a DIY cnc machine.
    I looked into the K2 machines, but for what you get I just felt they were too expensive. For similar money, you can get a smaller shopbot with a lot more powerful motors and great support. So, I thought I'd look into building an aluminum machine similar to the K2. After asking if anyone had tried this, George of XZero contacted me with details of his machines. Well I'm finally putting together my XZero machine. Thought I'd do a build log.
    So, here we go...
    Scott ...
    RMGreen Videos - Instructional Videos for Woodworking, CNC, Guitar Building
    Mar 2009
    388
    Boxes as received. Took about 2 weeks to get to me (Seattle) from canada.
    Mar 2009
    388
    Contents of boxes before unwrapping...
    Mar 2009
    388
    All the parts
    Mar 2009
    388
    Rails as shipped. These are mounted to the 8040 but not tightened down or aligned. You'll need to do that...
    Attached Thumbnails Attached Thumbnails IMG_8063 (Large).jpg   IMG_8064 (Large).jpg
    Mar 2009
    388
    Bolts to put the machine together. George throws them all into a bag. I separated mine before I started. George also forgot to send me M5x20 bolts needed to mount the gantry to the machine.
    Mar 2009
    388
    First shots of Rails mounted to endplates...
    Attached Thumbnails Attached Thumbnails IMG_8067 (Large).jpg   IMG_8068 (Large).jpg
    Mar 2009
    388
    Huge 2525 ballscrew and mount.
    Mar 2009
    388
    So, the motor end of the 2525 wont go through the endplate with the lovejoy installed. Also, once the lovejoy is through there is no clearance to get to the allen bolts. I had to grind the head of the allen bolt down.
    Attached Thumbnails Attached Thumbnails IMG_8071 (Large).jpg   IMG_8072 (Large).jpg
    Mar 2009
    388
    Pictures of the HiWin bearings. Important: There is a plastic carrier in the middle of the bearing before you install it. Dont remove this before you put it on the rail. As you are placing it on the rail make sure you let the rail push the carrier out.
    Attached Thumbnails Attached Thumbnails IMG_8074 (Large).jpg   IMG_8075 (Large).jpg   IMG_8077 (Large).jpg   IMG_8078 (Large).jpg
    Mar 2009
    388
    Frame completed. Right now I'm just putting the machine together to make sure everything fits. I will locktite everything after I get it assembled.
    Mar 2009
    388
    One of the gantry sides mounted. Later noticed after I got gantry on the machine that I had it backwards. No problem, just had to take the bolts out of the gantry sides to bearings, flip the gantry around and it was fixed.
    Mar 2009
    388
    More progress on the gantry.
    Mar 2009
    388
    Dial indicator that I used to align the rails to the top of the 8040.
    Attached Thumbnails Attached Thumbnails IMG_8090 (Large).jpg   IMG_8092 (Large).jpg
    Mar 2009
    388
    Y and Z motors mounted and tested. All moved well.
    At this point I am stuck. George just shipped the table top and a few of the parts I need to finish the machine.
    Jun 2007
    3891
    shiny.
    Apr 2009
    174
    thread?
    this shaft and coupling has thread?
    Quote Originally Posted by sagreen View Post
    Mar 2009
    388
    Quote Originally Posted by jassaf View Post
    The thread you are seeing is the ballscrew. The end of the ball screw has a shaft coming out of it that the lovejoy mounts to. The lovejoy is split and has a allen head bolt to tighten it up. That bolt must be ground down.
    Scott...
    Jun 2007
    3891
    the coupling does thread onto the ball screw to hold the bearing tight, then clamps to lock down. this was on the earlier machines. the newer machines no longer have this setup.
    Apr 2009
    174
    i understand, only by pressure: the end of the shaft without thread. thanks
    Quote Originally Posted by ihavenofish View Post
Page 1 of 8 123
  1. Newbie - To build or not to build Router/Plasma Table
    By dfranks in forum Waterjet General Topics
    Last Post: 04-08-2011, 05:16 AM
  2. Joe's 4x4 hybrid build/2006 build
    By krap101 in forum DIY CNC Router Table Machines
    Last Post: 08-09-2010, 11:30 AM
  3. NEW BUILD: PVC as a build material
    By Smiler in forum DIY CNC Router Table Machines
    Last Post: 11-13-2009, 11:57 PM
  4. New Large Table Build in Houston, TX (Build Log)
    By anitel in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 12-30-2008, 09:45 AM
