586,546 active members*
3,205 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Floppy drive emulator for A2100
    Oct 2009
    24
    I am seeing some USB to floppy emulators on eBay for <$50 and was wondering if anyone has tried one of these. Seems like a nice way to enable USB on an A2100 (although limited to 1.44MB files).
    May 2008
    9
    I haven't tried one yet, but I am interested as well. I have one machine that has a floppy drive for backups. Note that the cheap ones mention sewing machines and keyboards. The expensive ones mention industrial stuff like robots, but I would think that the emulation would be pretty much the same since you are doing it at the hardware level. I wouldn't mind paying more if I knew the difference. Funny, I just did a cleanup of some old machines... now I wish I had one to experiment with...
    Jan 2008
    83
    I put one in one of our Sabre 1500's, it works very well and have them in all of our equipment now. It was the more expensive version than what is on ebay, as this was awhile back when these first came out, but the others are the cheaper versions. The only problem we had was when we used a flash drive that was formatted in NTSB; must be in FAT format. It also has the ability to have CAT5 cable attached and hooked to the network; that's my next step.
    Mar 2011
    to kccrusher
    I'd be interested too. Most A2100 run on a version of WinNT 3.5 or 4.0 which isn't supposed to support USB...
    The A2100Di controls do support it - they use Win2K as the OS.
    Sep 2013
    9
    This is also floppy emulator:
    Floppy emulator SD card drive-Floppy emuDrive
  1. Hard Drive Options for A2100
    By cnckid in forum Cincinnati CNC
    Last Post: 12-18-2010, 06:22 AM
  2. A2100 hard drive cloning
    By mmckell in forum Cincinnati CNC
    Last Post: 09-28-2010, 03:34 PM
  3. 3 ½ floppy drive to USB flash drive readers
    By scadvice in forum CNC Machine Related Electronics
    Last Post: 08-10-2010, 05:43 PM
  4. DNC from floppy drive
    By jwknow in forum Haas Mills
    Last Post: 03-11-2010, 03:39 PM
  5. Floppy Drive
    By advt001 in forum Cincinnati CNC
    Last Post: 10-12-2008, 03:35 AM
