586,560 active members*
3,339 visitors online*
Thread: Taig Twins
Page 1 of 3 123
Results 1 to 20 of 41
    Dec 2007
    72
    Taig Twins
    I am building from scratch a manual electric drive Taig and a CNC Taig , they will be setup as neighbors or side by side . Here is a picture of my old manual electric servo drive and all the accesories . this unit is almost 20 years old and will be retired by these two units once done
    Also posted a picture of my CNC mill doing most of the mods
    Attached Thumbnails Attached Thumbnails DSC03071.jpg   DSC03073.jpg   DSC09363.jpg   DSC03070.jpg
    Dec 2007
    72
    Here is the start of the twins , concentrating on the drive assemblies , 4 new gates V-belts on there way in the mail
    Attached Thumbnails Attached Thumbnails DSC01432.jpg   DSC01434.jpg   DSC01456.jpg   DSC01457.jpg
    Dec 2007
    72
    More work done , Twin A will be the manual electric lathe...the servo motor mounts , drives with anti backlash 32 pitch gear and a machined low profile coupler
    Attached Thumbnails Attached Thumbnails DSC01460.jpg   DSC01497.jpg   DSC01499.jpg   DSC01500.jpg
    Dec 2007
    72
    A few more closeups
    Attached Thumbnails Attached Thumbnails DSC01507.jpg   DSC01508.jpg   DSC01509.jpg   DSC01510.jpg
    Jun 2003
    8
    Nice setup there. Thanks for sharing.
    Dec 2007
    72
    Thank you.....I am now starting to fabricate the CNC drive assembly
    Jul 2003
    586
    what kind of parts are you making with these? or are planning to?
    Dec 2007
    72
    I run Remote Control boats and try to make as many parts as I can , these lathes will really be for nothing specific , more or less just to help me out with the hobby boating
    coupler video
    [nomedia="http://www.youtube.com/watch?v=x6WI0MIzlHE"]YouTube - Birth of a coupler the sequel[/nomedia]
    A boating run
    [nomedia="http://www.youtube.com/watch?v=3UJ-fZfbtKQ&feature=fvsr"]YouTube - SNIPER EDMONTON FE RUN[/nomedia]
    Mill & Lathe making motor water jacket
    [nomedia="http://www.youtube.com/watch?v=qoW7rW_EsjY"]YouTube - Milling cooling jacket[/nomedia]
    Jul 2007
    1602
    Very nice work. What motors are you using on the lathes and the mill?
    bob
    Dec 2007
    72
    Thank you
    The original lathe in post #1 and the CNC mill both have a 2hp ac/dc treadmill motor that uses a variable a/c control for RPM , The mills motor I had the center casing chromed , The a/c controler can be bought on ebay for $20 . The new lathes have a 32 volt dc motor that will take 110ac through a voltage regulator and a rectifier block . I will probably never get close to full power with these since I never have with the old lathe .
    The new lathe motors were from a machine at work that was 20 some years old , I completely stripped them down and machined the front and rear face plates and painted the center section black . Apon taking them apart for observation they were extreemly well built and would easily take the task on with ease
    Here is where I am now with the CNC twin
    Attached Thumbnails Attached Thumbnails DSC01511.jpg   DSC01512.jpg   DSC01514.jpg
    Dec 2007
    72
    Machined in leadscrew nut , Its a part off of the taig mill along with the leadscrew
    Attached Thumbnails Attached Thumbnails DSC01516.jpg   DSC01517.jpg   DSC01518.jpg
    Dec 2007
    72
    Both CNC steppers mounted with leadscrew
    Attached Thumbnails Attached Thumbnails DSC01424.jpg   DSC01426.jpg   DSC01427.jpg   DSC01429.jpg
    Dec 2007
    72
    New one - to - one stepper cogged pulleys and new mount made to add further bracing with the help of the headstock
    Dec 2007
    72
    The Taig twins setup is done , the first CNC Taig is a leadscrew setup and the second uses the rack and gear setup .
    Attached Thumbnails Attached Thumbnails DSC01736.jpg   DSC01737.jpg   DSC01738.jpg   DSC01739.jpg
    Oct 2009
    38
    wow those are awesome! do you have any updates?? I would love to hear more about your lathes man, fantastic!
    Dec 2007
    72
    Quote Originally Posted by MynamesKenny19 View Post
    Thanks Kenny
    I just posted yesterday so thats about as far as I have got with these , there is one more little item I need to do and that is a front and rear rubber squeegee system for the carriage as no bits of metal go under the carriage and table . works great on my manual Taig .
    I am writing the G-code to do couplers like in this video . the input shaft holes I will do manually but the coupler bodies will be done with the CNC units .
    [ame="http://www.youtube.com/watch?v=x6WI0MIzlHE"]Birth of a coupler the sequel - YouTube[/ame]
    Oct 2009
    38
    I think the rubber would work better than mine, I use a piece of leather, it works pretty well but it could be better. On your leadscrew, which screw do you use, the one for the 2018 mill with stock x axis or the 2019 mill with the 12" X travel?
    I like how you mounted your leadscrew, barely did anything to the carriage. Genius! :banana:
    Dec 2007
    72
    It was the leadscrew for the 2019 but I believe that one comes in a short and long length , I opted for the shorter one and still cut it to length as to not hang out to far , then very gently debured the cut end .
    Oct 2009
    38
    How did you fix the tailstock end of the screw, just a simple bearing pressed into the plate?
    Dec 2007
    72
    Yes Kenny that is correct but it isn't 100% necessary , It will function just as good without it . the headstock and carriage support is really all that is needed
Page 1 of 3 123
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-19-2017, 04:38 PM
  2. My Taig.
    By impact in forum Benchtop Machines
    Last Post: 03-11-2009, 12:35 AM
  3. One way to end up with a Taig...
    By shw911 in forum Taig Mills / Lathes
    Last Post: 01-29-2009, 12:50 AM
  4. Taig CNC
    By GCWheeler in forum Mini Lathe
    Last Post: 01-19-2008, 10:19 PM
  5. EDM for a Taig?
    By teilhardo in forum Waterjet General Topics
    Last Post: 03-05-2004, 12:36 AM
