I could not think of how to word my issue...We are cutting cast iron, and trying to hold a 12 micron tolerance. We have done this for years, and have done it well, but the best guys we have have not been able to figure it out...If the size of the parts is too big, you can offset it down to where it needs to be, but we need to maintain a zero dimension over a little distance. we have a taper adjustment in the program, and can alter the finish point on X, which works, up until you get around 10 microns of differance between start point, and finish point. I have over adjusted the program, checked backlash, indacated from this to that, that to this, that, to that....I do not see much movement on my indicator....I am at my whits end.
We previously scrapped the gib, (side to side gib). But, I wonder what kind of wear pattern should there be...Even through out the gib, or two "patches" on both ends.
New ball screw, and bearings which worked for a while. Nothing seems to be rubbing on the part, this is a finish cut with a +/- 0.08mm inprocess rough cut leaving 0.8mm of material for the finish, so the stock is controlled, and not rough casting....
Any suggestions/questions would be wonderful. Thanks: John
