Hi all,
im building a cnc machine and iv bought a cnc controller which basically does everything i need. I have bought a laser module with 2.5watts of power and it runs about 3 amp. Iv been told its interface has a ttl input. My interface ion the board is designed i think for a motor because it is voltage controlled via p.port. on p.c. Has anybody or does anybody no what set up can be used to drive a laser with this board;
http://cgi.ebay.co.uk/New-0-5-2-5A-3...item3a61c03e8d
im using mach3, would you run a plasma profile and have continuous voltage on spindle output? im gona try and post a pic of the laser its self, its quite a beast, iv yet to handle it my self. It runs a peltier cooler and has a range of about 15mm to 150mm with good cutting depth.
