586,131 active members*
2,840 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > How can I tell if Arrow500 has 4th axis enabled?
    Oct 2009
    24
    I recently purchased an Arrow 500 and have been considering installing a 4th axis (or 5th if you count the spindle). All the wiring and connectors are present and in good shape. However, I have no idea if my installation of the s/w has this feature enabled. Anyone know where I look to see if my machine is licensed for the extra axis?
    Oct 2008
    123
    4th Axis
    Hello
    to check if the 4th axis option is enabled
    press MORE
    press SYSTEM CONFIGURATION
    press PURCHASED OPTIONS
    page down and look at option 20 - 1ST ADDITIONAL AXIS. If it is marked as PERMANENT then you can use the axis.
    all Arrows were wired to accept a 4th axis so all connections should be present, however it is probable that you will need a Kollmorgen 6 amp drive. check in the panel and see if there is a 4th axis drive present. standard machines have a power supply, spindle drive and 3 axis drives (x,y,z). for 4th axis you would need another drive.
    e-mail me at [email protected] if any more questions
    regards
    mallardfizz
    Oct 2009
    24
    Thanks! Looks like I'm good on the license, then. Now I get to start looking for an an affordable drive.
  1. ARROW500 OPERATING SOFTWARE
    By larry180 in forum Cincinnati CNC
    Last Post: 11-15-2021, 01:54 PM
  2. Arrow500
    By rai in forum Cincinnati CNC
    Last Post: 08-21-2010, 06:21 PM
  3. Cincinnati Arrow500 Problem
    By sompob in forum DNC Problems and Solutions
    Last Post: 07-22-2010, 04:13 AM
  4. Axis jog gets weird when backlash enabled
    By protrackcorp in forum Machines running Mach Software
    Last Post: 12-21-2009, 03:03 PM
  5. need help for Arrow500
    Last Post: 11-02-2009, 04:09 PM
