587,004 active members*
2,768 visitors online*
IndustryArena Forum > Business Practices > Business Practices / Pricing > What would I really be getting into? What would I need?
Results 1 to 17 of 17
    Jan 2011
    This is my first real thread here, so please forgive me if I'm a naive.
    I'm an anime (Japanese cartoons) fan, and I started going to conventions in costume the summer I got out of high school. The characters I go in costume as often times carry very fanciful objects. As a result, I had to make many of these objects, and I found that it's a great deal of fun for me. As I'd show my works to others at these events, many were astounded by my work, and it made me wonder if this would be something that I could somehow make a career out of.
    Fast forward about 4 years, and I've made many more, and significantly more intricate props. I'm currently in college for psychology, but I still love doing this kind of stuff. After tying to get commissions and get some semblance of a start, I realized that what I'd need to make this sort of thing successful is a number of small objects that I could sell at a low cost and have people purchasing on a frequent basis.
    The problem is that in order to make many of these sorts of things, I'd need to be able to put them out in larger numbers than 5 at a time, and I'd need to be able to do it in a way that allows me to duplicate my works in a cost effective fashion. As of right now, I really only have typical power tools (disc sander, band saw, drill press, table saw, etc.), and all the details get done by hand tools (carving chisels, dremel tool, etc). I recently saw a carvewright machine in a woodcraft catalog, and since I primarily work with wood, plastics, foam, & aluminum, it seemed like a tool that I could get for a reasonable price that would allow me to start doing this sort of stuff in a more cost effective way.
    For those of you who know what one is, the carve wright can only handle materials that are 14.5" wide and 5" tall, but it can supposedly work with materials of any length. I started reading some reviews, and I found out that it's a good idea that's just too riddled with quality control issues to justify even a used price tag. That brings me to the idea I'd entertained for years of a CNC mill. But they're just so expensive that I'd probably have to take out a loan to purchase one.
    Then, I don't have any experience at all with CAD or CAM software, and all sources indicated that the carvewright software was extraordinarily simple to use, making it appeal to me for that reason as well. I don't mind taking classes, working hard to learn the programs, or even the $500 price tag for some of the suites, but the price of the CNC mill itself concerns me.
    I figure I'd need a 4'x6' machine at the largest. I'd like to have the ability to cut fairly deep on the Z axis too. It would NEED to be able to cut wood, foam, plastics, and aluminum. If I could get one that can cut ferrous metals as well, that'd be great, but it's not a necessity for what I do.
    I contacted torchmate, and they gave me a price quote of $15,500 shipped for a machine from them, but I've seen shopbots and other machines similar in capabilities for about $8,000-$10,000.
    I guess what I'm asking is this:
    If I really want to get serious about making stuff like what's in the pictures below, what do I NEED in terms of training, software, and a machine?
    Jan 2011
    66 views and no responses? Please help me guys.
    Oct 2006
    669
    Quote Originally Posted by PeppermintRhino View Post
    Realistically you need a real mill to handle machining aluminum in any meaningful way. Yes you can use a homemade CNC router on aluminum, but it's several steps below simply automating what has been for you until now a manual process. I have not been impressed with what I've seen boasted as "machined aluminum" from a router...the DOC (depth of cut), feed-rate, cycle times, accuracy and surface finish were laughable at best. I guess if it only needs to be "good enough" or "passable" then it's an acceptable compromise machine, and allows to you produce your props faster than by hand.
    You have a STEEP road ahead of you...many of your props are 3 dimensional and would require a decent CAD system, which runs from $500 to $100,000 depending on your needs...along with the learning curve that goes with it.
    From there if you don't have the know-how to program your shapes by hand via G-code & M-code, then you also require a CAM system, which again runs anywhere from $500 to $100,000 depending on your needs.
    You can use a ShopBot, MechMate, TorchMate etc router for all of your materials. Aluminum would be better machined on a mill, but if chatter-marks and inaccurate dimensions are acceptable to you, a router will suffice. A router is the only machine at a reasonable price-point available to you with the operating envelope you are looking for. Any mill that would be able to machine the 3' plus length you would need is going to be 6-figures, easy. There are work-arounds for smaller machines, but with your lack of experience, that is just another few trudges on your road ahead.
    Without a realistic budget and operating demands, it's impossible to give you any reasonable advice. Any idiot can voice their opinion, but then that's merely the opinion of an idiot...not exactly what I would be steering my hard-earned money in the direction of.
    Jan 2011
    Quote Originally Posted by 307startup View Post
    What's the difference between a CNC mill and a CNC router? I was under the impression that they were somewhat, if not entirely synonymous. I would like to see some of the pictures of the shoddy craftsmanship you're referring to so that I could make a better decision about whether that level of precision is good enough for what I do. I could live with a device that's limited to foam, plastics, and wood, but there are a few times though where aluminum is ideal though.
    I'm well aware of the fact that the objects in my original post are very detailed and three dimensional, and I knew this wasn't going to be something I could learn to do in the span of a weekend or even a month.
    A friend of mine pointed me to TurboCNC, and I was blown away when I saw the page of stuff that was made using that software. For a program that sells for about $100, I thought the level of precision and detail was perfectly, if not more than adequate for what I want to do. The page can be found here:DAK Engineering - TurboCNC Gallery
    I have been told that there are a number of different plans available for mills that have a high end of $600 for a price tag, and the same gentleman that pointed me to turboCNC also told me that I could get away with building a home-made mill/router to the dimensions I specified earlier for under $2k and that it would be capable of cutting titanium and steel if necessary.
    I apologize if I'm coming across as indignant, but I did a decent amount of research after making my initial post, and I'm just not sure that a 6 figure price tag is necessary. I'm nowhere close to dismissing the process of learning this skill as anything even remotely close to easy, and I know I'm not going to be building this sort of thing for a few hundred dollars. I just don't believe that I'm going to have to spend $100k to get what I need.
    If I did have to give a definitive budget for what I'd be looking to spend on the entire package, I'd probably have to say $3,500 total. Maybe that's a foolish price tag to stick on this, but from what I've seen and been told thus far by people who have more knowledge in this arena than myself, I'm not so sure that it is.
    Oct 2006
    669
    If a CNC mill is synonymous or = to a CNC Router, then anything with 4 wheels is synonymous or = to a car. Machine tools are built for specific purposes...that is why they are engineered the way they are. Just as a truck has a heavier-duty frame & powertrain to pull loads, so is a CNC mill frame built to handle the loads imposed by the cutting tool and the reactant force caused by the material.
    If TurboCNC suffices for your needs, that is a good choice. If not, it's $100 that would have been better spent elsewhere.
    Again...you are confused about the differences between a mill and a router. Rigidity and layout are completely different. A router/plasma/laser/waterjet/etc.-table are built for sheet goods. The gantry isn't stiff enough to handle the axial and upward thrust of a cutting tool on denser materials.
    Your "friend" doesn't know **** from applebutter if he thinks a $600 MDF router is going to cut steel & titanium. If a home-built CNC router made out of MDF or aluminum extrusions would suffice for cutting steel or titanium, shops wouldn't invest millions of dollars in equipment for contracts with Boeing or Caterpillar, now would they? Rub any two materials together long enough and you'll get material removal...doesn't necessarily mean that cutting is going on.
    I didn't say that a 6 figure pricetag was necessary. I said that that is what the price spectrum runs across.
    Ok...you win. Hobbyists know better than professionals. Maybe this is why no one else has contributed to your thread? You admit you don't know anything, and then you try to tell me what can be done with what equipment and software on what budget. You betcha. Enjoy that long trudge up that steep hill.
    Oct 2009
    272
    Rocket science or Sience fiction?
    PeppermintRhino,
    From my research on the "Zone" it could be possible to build a CNC ROUTER that would meet your needs for around $3500.00, this does not include the computer & software to design parts and run the CNC. The price tag for a DIY machine is based upon three main points:
    1) Design parameters, to include cutting envelope, feed rates, cycle times, accuracy and repeatability. Materials to be machined. This determines the mechanicals, electronics and so forth.
    2) What is the machine constucted of:
    MDF(which may or may not machine aluminium), 80/20 aluminium extrusion, welded steel or a combination of materials and construction methods
    Ballscrews, Acme, R&P or belt drive.
    Stepper motors, Servo motors or a hamster in a cage wheel.
    3) How much of the machine can you personally construct:
    Stepper drivers, breakout board, PSU.
    Drill & tap aluminium, weld steel, chew MDF.
    307startup is right when he talks about cutting forces and surface finishes. As far as tolerances and accuracy, he may be a little off base. You are not trying to make parts for the space shuttle just some props to play with. There WILL be some hand work involved if you want a perfect fit and a mirror finish on aluminium. However, you will have the TIME to do this because the router did the bulk of the fabrication.
    Do some more research in the DIY forum and ask alot of questions. MOST people here on the "Zone" are ready & willing to HELP. Learn what's involved in building a machine that would work for YOU. You may decide to purchase a "Plug & Play" machine or choose to build your own design.
    Good luck, whatever road you choose to go down. But DO go down the road, as it can be done for way less that $100,000! Many have built quality machines ranging from $3,000.00 and up.
    Randy,
    I may not be good....
    But I am S L O W!!
    Oct 2010
    65
    Take a look at this guy, kind of similar stuff to what you need?
    looks very low cost and the work looks great,
    Vrogy.net » CNC
    Jan 2011
    I didn't say I knew better, I was just telling you what I've found and what I've heard from others who have more experience that I actually know in real life. I even apologized for potentially sounding ungrateful for the advice in advance. That being said, your initial post itself sounded remarkably condescending, as though you were speaking to a child. It's like you were throwing extraordinarily high price tags out there just to try and scare me away. I realize that companies don't sink millions of dollars into their machines when they make parts for the aircrafts and government contracts, but I'm not making anything in those kinds of numbers, nor do I need to build things to that level of precision because nobody's life depends on the functionality of what I make.
    Jan 2011
    Quote Originally Posted by DIYaholic View Post
    PeppermintRhino,
    Randy,
    Randy, thank you for that info, I'll proceed on over to the DIY section and see what other people have done and what might work for me. I never believed that 307starup was wrong about anything but the price points, so it's helpful to know that the difference is going to be in the load. Thank you for also pointing out that the accuracy, scale, and importance of the things I make isn't anywhere near comparable to what companies like Boeing and Lockheed Martin do.
    Quote Originally Posted by Markwind View Post
    Vrogy.net » CNC
    That's exactly the kind of thing I'm looking to do. Thanks a lot for showing me this.
    I don't think a router or mill is going to allow you to make those parts fast enough to make money at it. But it depends on the level of detail you're looking for.
    Jan 2011
    As far as level of detail goes, If I can achieve the kind of detail that's on the assault rifle in the 2nd and 3rd picture, that'll be perfect for what I'm looking to do. Why do you say that I may not be able to make them fast enough though?
    Jul 2007
    148
    You could try a different approach and make your props like the special effects industry does. This magazine sometimes has great articles about companies that make props for the TV and movie industry, Cinefex :: Visual Effects Magazine :: Special Effects :: Computer Graphics . The magazine also has lots of advertisers listed that sell the supplies. Basically the most cost effective way for you to sell those items at a reasonable price, in my opinion, would be to make a mold and vaccum form them out of polystyrene sheets and then glue them together, add some paint and then you are done.
    Jun 2007
    73
    I agree with Ger21. The level of detail seen in the 2nd or 3rd picture is indeed achievable with advanced CAM software and a nice CNC Mill, but it is nowhere near practical. The programming, setup, fixturing and machining times would be astronomical. And if you want to sell these things, theyve gotta be decent quality.
    Starting from nothing, it would probably cost $50,000-$100,000 in machines, tooling, software and time to make the gun shown in #3 by milling it from a solid block of aluminum, in a professional manner. (Disclaimer: rough estimate).
    My initial feeling here would be to mold these. Injection molding would be expensive, but vacuform molding might get a close product. (Think Mythbusters making a fake head) I would make the molds by hand, and you could probably produce a few hundred pieces.
    $.02
    Mar 2010
    275
    HDU?
    Okay, if these are props, and we're talking dozens, maybe, not thousands, it might make sense to machine them out of high density urethane foam (HDU), and add fancy finishes.
    Tooling board is widely used to put a non-working prototype shape in the designer's hands quickly. The material is expensive, but cuts quickly and takes finishes extremely well. A very light duty machine can cut it. One well known brand is "Renshape".
    If you are already skilled with 3D modeling in a program like Blender, all you'd need would be something like Meshcam to turn stl files into toolpaths.
    Here are some examples of what can be done with HDU:
    Sawatzky's Imagination Corporation. Theme park design and construction.
    -Jim Hart
    My main machine: Multicam MG series (MG101) with original Extratech H971 controller, Minarik servo motors, Electro-Craft BRU-series drives, 4KW Colombo. Let's talk Multicam!
    I was thinking along the lines of what Excel said, making molds. If you want ready to finish (little to no sanding) straight off the machine, expect several hours to make the gun you linked too.
    The original images you posted had far more detail than this one.
    Jan 2011
    Quote Originally Posted by Excelmachine View Post
    I honestly had not thought of that idea. I just thought a CNC machine of some sort would be the best route because I always thought it was very fast. The fact that it's automated and could easily reproduce the same thing again and again also made it seem like a good option.
    Quote Originally Posted by Smrtman5 View Post
    $.02
    I'd most likely be making something like that out of wood or high density foam. I use aluminum once in a while, but I'm primarily working with wood and materials of that density. I just wanted to see if it was possible to make a machine that could do everything I'd ever need.
    Quote Originally Posted by Boltz View Post
    -Jim Hart
    Jim, that would also work beautifully. I didn't know that materials like the high density polyurethane sheets existed, and if they machine quickly, then I should be able to make molds in no time flat.
    I figured there would be some sanding involved, but I didn't think it would be that much. I guess if I create molds from an original though, it doesn't matter that much in the long run if it takes me a while to make a prototype to form a mold from. I felt like the level of detail that the assault rifle I linked to and the original pictures I posted were comparable in the level of detail they had.
    Apr 2007
    1955
    I would like to suggest that the "process" of learning cad and machining might actually be mind restricting for you. I say that, not because people that know CAD are narrow minded, but because it is not so easy to CAD draw complex objects. The "process" of learning CAD could have the adverse effect of making you think in a less artistic way, and your approach could become simplistic in order to accomodate what you know how to draw in CAD.
    The CAD and CAM software alone can easily swamp your budget - by quite a margin. I am sadly in this same area as you, so I have looked around a bit.
    An alternative, which allows you to continue your existing artistic creativity, while still learning in more detail about what is really needed, perhaps consider to work with a firm that is setup to do the portion of the work that you are not setup for. One such firm (and I am sure there are others) is www.adm-works.com near LA. You might ask how I know them - well, I met the owner at my daughter's wedding (his daugher was the flower girl, some kind of cousin of the groom)
    http://www.adm-works.com/
    I was in LA a few months later and stopped to visit the shop. Basically, they are setup so that anyone with an artistic idea can bring in a hand made sample, of any size and random shape. They have a high resolution 3D scanner that captures the shape, then they clean it up with CAD and CAM until it is ready to be cut out. The scanning process means it does not matter how complex your shape is, as that is the machines problem, not yours.
    You just tell them what size you want it to be, and what material, and they can make it for you, right there in the shop, as many as you want. They have small machines and large ones - the big one can carve in one piece an object the size of a full size van.
    The also make full size foam parts that you use to make a mold from. They can send out the foam blank for you and get things cast, etc nearby. One of the projects on the floor were some cast clouds. The artist had come to them with some lumps of clay. While there were in a meeting room, he squished them in his hand, and sat them down on the scanner. From this, they scanned them, made blanks, and had them cast in bronze. (several ft in diameter size)
    I don't do any consulting work for them, but they seem to know what they are doing. They are NOT artist though - that has to come from your side. All of this takes some time, so its not going to come free, although I have no idea what he charges, it must be reasonable or he wouldn't still be in business.
    In answer to one of your questions above, a mill and a router are similar, but different. Although there is overlap in some designs, in general, mills are designed to machine metals at relatively lower rotation rates, high torque, and low feed rates, which optimizes the finish for those metallic materials.
    Routers are designed to operate at higher rotation rates, high feed rates, and lower torque, which optimizes the finish for wood and foam like materials.
    A router might need to drive the bit along at 200 - 800 inches per minute just to keep from burning the wood from friction, while a mill would usually go 1/10th of that.
    The cutting forces in Al and steel cutting are dramatically higher compared to wood - again - 10x more is not uncommon. This tends to drive the design of mills to metal on metal slides type designs, while wood routers tend to be designed with sliding round bearings.
    The same metal on metal designs for mills, also make the machinists protective about just what they will put in them. Wood is a lot more acidic and abrasive than I ever gave it credit for. Wood routers are designed so that this is less of an issue, but a precision metal mill can be damaged running a 3D cut out in relatively soft red wood, due to the tanic acid, and its high silica (literally sand) content. Strange, isn't it.
    I mostly work with wood, and my brother mostly with metals, so we have almost no overlap of tools other than hand tools. I have 2x4s and plywood stocked in the garage for whatever comes along, while he hardly has a stick of wood on his property. He has various Al and steel stock around, while I have hardly any. It took me a long time to understand this.
    Good luck with your project.
    Harry
    BTW- your projects looks like they will often need 4D and maybe 5D cutting to really come out, not the 3D that most hobby people own. That is why you got the comments about the cost of the machines being in the 100K range.
